KitchenAid KSB5CR Power Cable Replacement
    1. KitchenAid KSB5CR Power Cable Replacement, Removing the Back Panel Part 1: step 1, image 1 of 3 KitchenAid KSB5CR Power Cable Replacement, Removing the Back Panel Part 1: step 1, image 2 of 3 KitchenAid KSB5CR Power Cable Replacement, Removing the Back Panel Part 1: step 1, image 3 of 3
      • Remove the glass container and place the blender upside down on a solid surface.
      • Remove the four rubber feet using the needle nose pliers.
      • Remove the four #7.5 Phillips 25mm screws that were located underneath the rubber feet using the Phillips #2 screwdriver.
      Ask FixBot
    2. KitchenAid KSB5CR Power Cable Replacement, Removing the Back Panel Part 2: step 2, image 1 of 1
      • Lift the back panel up, sliding it along the power cord.
      Ask FixBot
    1. KitchenAid KSB5CR Power Cable Replacement, Freeing the Power Cable: step 3, image 1 of 1
      • Lift up on the power cable to pop it out of its holder.
      Ask FixBot
    2. KitchenAid KSB5CR Power Cable Replacement, Detaching the White and Black Wires: step 4, image 1 of 2 KitchenAid KSB5CR Power Cable Replacement, Detaching the White and Black Wires: step 4, image 2 of 2
      • Be gentle with the knife or you will break the circuit board.
      • Slide the knife into the metal loop holding the insulation before the white copper wire, and wiggle it back and forth until it loosens.
      • Pull the wire out from the metal loop that you loosened.
      • Repeat this process with the black copper wire.
      Ask FixBot
    3. KitchenAid KSB5CR Power Cable Replacement, Detatching the Green Wire: step 5, image 1 of 2 KitchenAid KSB5CR Power Cable Replacement, Detatching the Green Wire: step 5, image 2 of 2
      • Using the Phillips #2 screwdriver, remove the #8 Phillips 6mm screw to which the green wire is attached.
      Ask FixBot
Cameron Geehr
745 Reputation
6 Guides authored
Cal Poly, Team 12-5, Forte Fall 2014 Member of Cal Poly, Team 12-5, Forte Fall 2014
CPSU-FORTE-F14S12G5
5 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 25
All Time: 976
