KitchenAid KSB5CR Fan Replacement
    1. KitchenAid KSB5CR Fan Replacement, Removing the Back Panel Part 1: step 1, image 1 of 3 KitchenAid KSB5CR Fan Replacement, Removing the Back Panel Part 1: step 1, image 2 of 3 KitchenAid KSB5CR Fan Replacement, Removing the Back Panel Part 1: step 1, image 3 of 3
      • Remove the glass container and place the blender upside down on a solid surface.
      • Remove the four rubber feet using the needle nose pliers.
      • Remove the four #7.5 Phillips 25mm screws that were located underneath the rubber feet using the Phillips #2 screwdriver.
      Ask FixBot
    2. KitchenAid KSB5CR Fan Replacement, Removing the Back Panel Part 2: step 2, image 1 of 1
      • Lift the back panel up, sliding it along the power cord.
      Ask FixBot
    1. KitchenAid KSB5CR Fan Replacement, Removing the Fan Chassis Part 1: step 3, image 1 of 3 KitchenAid KSB5CR Fan Replacement, Removing the Fan Chassis Part 1: step 3, image 2 of 3 KitchenAid KSB5CR Fan Replacement, Removing the Fan Chassis Part 1: step 3, image 3 of 3
      • Remove the two #5 Phillips 95 mm machine screws using the Phillips #2 screwdriver.
      • Remove the rubber O-ring by lifting it up.
      • Remove the ribbon cable from the chassis by lifting it up.
      Ask FixBot
    2. KitchenAid KSB5CR Fan Replacement, Removing the Fan Chassis Part 2: step 4, image 1 of 3 KitchenAid KSB5CR Fan Replacement, Removing the Fan Chassis Part 2: step 4, image 2 of 3 KitchenAid KSB5CR Fan Replacement, Removing the Fan Chassis Part 2: step 4, image 3 of 3
      • Unhook the white wire that is looped around the peg by pulling it out of the clip.
      • Repeat this process with the red wire on the other side of the chassis.
      • Remove the end cap using the 8" needle nose pliers.
      • Pull up the fan chassis.
      Ask FixBot
    3. KitchenAid KSB5CR Fan Replacement, Removing the Fan: step 5, image 1 of 1
      • Remove the fan by lifting it upwards.
      • This step is difficult and requires force. Use of both hands is recommended.
      Ask FixBot
Cameron Geehr
745 Reputation
6 Guides authored
Cal Poly, Team 12-5, Forte Fall 2014 Member of Cal Poly, Team 12-5, Forte Fall 2014
CPSU-FORTE-F14S12G5
5 Members
72 Guides authored
3 Guide Comments
Hi,
Do you know if it is possible to convert Kitchenaid Artisan stand mixer to 240v, has anyone looked inside or know if i should change something.
Ancient warrior - Reply Share
Does raplacing the fan mean that the fan itself (when broken) can be ordered? So just the white plastic round part. If so, could someone please give me a reference number? Would be highly appreciated.
Hugo, the Netherlands.
Hugo - Reply Share
my blender turn on all the numbers light at the same time and is not working at all. do you know what the problem could be?
patricia - Reply Share
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 39
All Time: 2,771
