Up to 20% off select tools
KitchenAid KSB5CR Back Panel Removal
Views: 1.2K
View statistics:
Past 24 Hours:
3
Past 7 Days:
17
Past 30 Days:
87
All Time:
1,236
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 2 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
The back panel protects the internal components of the blender.
    1. KitchenAid KSB5CR Back Panel Removal, Removing the Back Panel Part 1: step 1, image 1 of 3 KitchenAid KSB5CR Back Panel Removal, Removing the Back Panel Part 1: step 1, image 2 of 3 KitchenAid KSB5CR Back Panel Removal, Removing the Back Panel Part 1: step 1, image 3 of 3
      • Remove the glass container and place the blender upside down on a solid surface.
      • Remove the four rubber feet using the needle nose pliers.
      • Remove the four #7.5 Phillips 25mm screws that were located underneath the rubber feet using the Phillips #2 screwdriver.
      Ask FixBot
    2. KitchenAid KSB5CR Back Panel Removal, Removing the Back Panel Part 2: step 2, image 1 of 1
      • Lift the back panel up, sliding it along the power cord.
      Ask FixBot
Author
with
Cameron Geehr
745 Reputation
6 Guides authored
Cal Poly, Team 12-5, Forte Fall 2014 Member of Cal Poly, Team 12-5, Forte Fall 2014
CPSU-FORTE-F14S12G5
5 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 17
Past 30 Days: 87
All Time: 1,236
