KitchenAid KHM512ER Power Cord Replacement
    1. KitchenAid KHM512ER Power Cord Replacement, Power Cord: step 1, image 1 of 2 KitchenAid KHM512ER Power Cord Replacement, Power Cord: step 1, image 2 of 2
      • Insert the back of a plastic opening tool into one of the beater holes
      • Apply force to pull the circular plastic part off.
      • If necessary, use the other side of the plastic opening tool to pry the circular plastic part off.
      Ask FixBot
    2. KitchenAid KHM512ER Power Cord Replacement: step 2, image 1 of 3 KitchenAid KHM512ER Power Cord Replacement: step 2, image 2 of 3 KitchenAid KHM512ER Power Cord Replacement: step 2, image 3 of 3
      • Use a plastic opening tool to remove the speed knob.
      • Pop up the panel with a plastic opening tool.
      • Use a plastic opening tool to pry the white plastic switch assembly out.
      Ask FixBot
    3. KitchenAid KHM512ER Power Cord Replacement: step 3, image 1 of 2 KitchenAid KHM512ER Power Cord Replacement: step 3, image 2 of 2
      • Use a Phillips 2 screwdriver to remove the two 20.0mm screws that hold the bottom plastic piece.
      • Your screwdriver may not be long or narrow enough to reach the screws in these holes. If that's the case, use another screwdriver.
      • Remove the bottom plastic piece using a plastic opening tool.
      Ask FixBot
    4. KitchenAid KHM512ER Power Cord Replacement: step 4, image 1 of 3 KitchenAid KHM512ER Power Cord Replacement: step 4, image 2 of 3 KitchenAid KHM512ER Power Cord Replacement: step 4, image 3 of 3
      • Using a Phillips 2 screwdriver, remove the three 20.0mm screws holding the motor assembly in place.
      • Use your hands to remove the motor assembly and circuit board.
      Ask FixBot
    5. KitchenAid KHM512ER Power Cord Replacement: step 5, image 1 of 3 KitchenAid KHM512ER Power Cord Replacement: step 5, image 2 of 3 KitchenAid KHM512ER Power Cord Replacement: step 5, image 3 of 3
      • Firmly grip the circuit board, and using pliers, remove the black and white power cord connectors from the circuit board.
      • Some force may be required. Be careful not to cut yourself on any electrical components.
      Ask FixBot
    6. KitchenAid KHM512ER Power Cord Replacement: step 6, image 1 of 3 KitchenAid KHM512ER Power Cord Replacement: step 6, image 2 of 3 KitchenAid KHM512ER Power Cord Replacement: step 6, image 3 of 3
      • Using a plastic opening tool, remove the white plastic clip on the inside of the bottom plastic piece.
      • Once it's loose, remove it with your fingers.
      • Pull the power cord through the hole.
      Ask FixBot
Brad Daniels
636 Reputation
3 Guides authored
USF Tampa, Team 2-3, Sullivan Spring 2016 Member of USF Tampa, Team 2-3, Sullivan Spring 2016
USFT-SULLIVAN-S16S2G3
3 Members
48 Guides authored
1 Guide Comment
where to find this cord?
Markian G.G. - Reply Share
Past 24 Hours: 0
Past 7 Days: 13
Past 30 Days: 38
All Time: 4,533
