KitchenAid KHM512ER Motor Replacement
    1. KitchenAid KHM512ER Motor Replacement, Motor: step 1, image 1 of 2 KitchenAid KHM512ER Motor Replacement, Motor: step 1, image 2 of 2
      • Insert the back of a plastic opening tool into one of the beater holes
      • Apply force to pull the circular plastic part off.
      • If necessary, use the other side of the plastic opening tool to pry the circular plastic part off.
      Ask FixBot
    2. KitchenAid KHM512ER Motor Replacement: step 2, image 1 of 2 KitchenAid KHM512ER Motor Replacement: step 2, image 2 of 2
      • Use a Phillips 2 screwdriver to remove the two 20mm screws holding the bottom plastic piece in place.
      • Remove the bottom plastic piece using a plastic opening tool.
      • Your screwdriver may not be long or narrow enough to reach the screws in these holes. If that's the case, use another screwdriver.
      Ask FixBot
    3. KitchenAid KHM512ER Motor Replacement: step 3, image 1 of 2 KitchenAid KHM512ER Motor Replacement: step 3, image 2 of 2
      • Using a Phillips 2 screwdriver, remove the three 20mm screws holding the motor assembly in place.
      • Use your hands to remove the motor assembly and circuit board.
      Ask FixBot
    4. KitchenAid KHM512ER Motor Replacement: step 4, image 1 of 3 KitchenAid KHM512ER Motor Replacement: step 4, image 2 of 3 KitchenAid KHM512ER Motor Replacement: step 4, image 3 of 3
      • Firmly grip the motor in your hand. Using pliers, pull the connectors off the motors.
      • Some force may be required. Be careful not to cut yourself on any electrical components.
      Ask FixBot
2 other people completed this guide.
[deleted]
134 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 7
Past 30 Days: 50
All Time: 5,513
