Up to 20% off select tools
KitchenAid KHM512ER Eject Button Spring Replacement
Views: 2.4K
View statistics:
Past 24 Hours:
6
Past 7 Days:
27
Past 30 Days:
114
All Time:
2,445
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 - 20 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
Beater Eject Button doesn't work? Follow this guide to replace it.
    1. KitchenAid KHM512ER Eject Button Spring Replacement, Eject Button Spring: step 1, image 1 of 2 KitchenAid KHM512ER Eject Button Spring Replacement, Eject Button Spring: step 1, image 2 of 2
      • Insert the back of a plastic opening tool into one of the beater holes.
      • Apply force to pull the circular plastic part off.
      • If necessary, use the other side of the plastic opening tool to pry the circular plastic part off.
      Ask FixBot
    2. KitchenAid KHM512ER Eject Button Spring Replacement: step 2, image 1 of 3 KitchenAid KHM512ER Eject Button Spring Replacement: step 2, image 2 of 3 KitchenAid KHM512ER Eject Button Spring Replacement: step 2, image 3 of 3
      • Use a plastic opening tool to remove the speed knob.
      • Use a plastic opening tool to remove the long plastic piece
      • Use a plastic opening tool to remove the speed switch.
      Ask FixBot
    3. KitchenAid KHM512ER Eject Button Spring Replacement: step 3, image 1 of 2 KitchenAid KHM512ER Eject Button Spring Replacement: step 3, image 2 of 2
      • Use a Phillips 2 screwdriver to remove the two 20.0mm screws holding the bottom plastic piece on.
      • Your screwdriver may not be long or narrow enough to reach the screws in these holes. If that's the case, use another screwdriver.
      • Remove the bottom plastic piece using a plastic opening tool.
      Ask FixBot
    4. KitchenAid KHM512ER Eject Button Spring Replacement: step 4, image 1 of 3 KitchenAid KHM512ER Eject Button Spring Replacement: step 4, image 2 of 3 KitchenAid KHM512ER Eject Button Spring Replacement: step 4, image 3 of 3
      • Using a Phillips 2 screwdriver, remove the three 20.0mm screws holding the motor assembly in place.
      • Use your hands to remove the motor assembly.
      • Use your hands to hold the eject button from one side while using the other hand to remove the circuit board.
      Ask FixBot
    5. KitchenAid KHM512ER Eject Button Spring Replacement: step 5, image 1 of 2 KitchenAid KHM512ER Eject Button Spring Replacement: step 5, image 2 of 2
      • Remove the eject button by pulling it from the inside of the mixer.
      • Hold the eject button firmly while pulling out the spring.
      Ask FixBot
2 other people completed this guide.
Author
with
Yuriy Zaynulin
191 Reputation
1 Guide authored
USF Tampa, Team 2-3, Sullivan Spring 2016 Member of USF Tampa, Team 2-3, Sullivan Spring 2016
USFT-SULLIVAN-S16S2G3
3 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 27
Past 30 Days: 114
All Time: 2,445
