Kitchen Gourmet Waffle Maker Release Latch Spring Replacement
    1. Kitchen Gourmet Waffle Maker Release Latch Spring Replacement, Release Latch Spring: step 1, image 1 of 1
      • Unplug the waffle maker.
      Ask FixBot
    2. Kitchen Gourmet Waffle Maker Release Latch Spring Replacement: step 2, image 1 of 3 Kitchen Gourmet Waffle Maker Release Latch Spring Replacement: step 2, image 2 of 3 Kitchen Gourmet Waffle Maker Release Latch Spring Replacement: step 2, image 3 of 3
      • Open the waffle maker.
      • Make sure the waffle maker's surface is not hot.
      Ask FixBot
    3. Kitchen Gourmet Waffle Maker Release Latch Spring Replacement: step 3, image 1 of 3 Kitchen Gourmet Waffle Maker Release Latch Spring Replacement: step 3, image 2 of 3 Kitchen Gourmet Waffle Maker Release Latch Spring Replacement: step 3, image 3 of 3
      • Spray the interior of the waffle maker with cleaning solution.
      • Clean and wipe down the surface.
      Ask FixBot
    4. Kitchen Gourmet Waffle Maker Release Latch Spring Replacement: step 4, image 1 of 2 Kitchen Gourmet Waffle Maker Release Latch Spring Replacement: step 4, image 2 of 2
      • Use a Phillips #1 screwdriver to remove the four screws that secure the plastic handle cover.
      • Spin in counterclockwise direction to loosen.
      Ask FixBot
    5. Kitchen Gourmet Waffle Maker Release Latch Spring Replacement: step 5, image 1 of 3 Kitchen Gourmet Waffle Maker Release Latch Spring Replacement: step 5, image 2 of 3 Kitchen Gourmet Waffle Maker Release Latch Spring Replacement: step 5, image 3 of 3
      • Carefully pull back the plastic cover, and gently remove the release latch.
      Ask FixBot
    6. Kitchen Gourmet Waffle Maker Release Latch Spring Replacement: step 6, image 1 of 2 Kitchen Gourmet Waffle Maker Release Latch Spring Replacement: step 6, image 2 of 2
      • Remove the spring from the latch.
      Ask FixBot
    7. Kitchen Gourmet Waffle Maker Release Latch Spring Replacement: step 7, image 1 of 3 Kitchen Gourmet Waffle Maker Release Latch Spring Replacement: step 7, image 2 of 3 Kitchen Gourmet Waffle Maker Release Latch Spring Replacement: step 7, image 3 of 3
      • Carefully replace with the new spring.
      • Pliers are recommended but removal with hands is fine.
      • Be careful not to bend the spring when pushing into the plastic handle.
      Ask FixBot
    8. Kitchen Gourmet Waffle Maker Release Latch Spring Replacement: step 8, image 1 of 3 Kitchen Gourmet Waffle Maker Release Latch Spring Replacement: step 8, image 2 of 3 Kitchen Gourmet Waffle Maker Release Latch Spring Replacement: step 8, image 3 of 3
      • Orient the release latch in the correct direction, and line up the spring.
      Ask FixBot
    9. Kitchen Gourmet Waffle Maker Release Latch Spring Replacement: step 9, image 1 of 3 Kitchen Gourmet Waffle Maker Release Latch Spring Replacement: step 9, image 2 of 3 Kitchen Gourmet Waffle Maker Release Latch Spring Replacement: step 9, image 3 of 3
      • Hold the latch in place.
      • Line up the screw holes on the plastic cover to the waffle maker lid.
      Ask FixBot
    10. Kitchen Gourmet Waffle Maker Release Latch Spring Replacement: step 10, image 1 of 2 Kitchen Gourmet Waffle Maker Release Latch Spring Replacement: step 10, image 2 of 2
      • Screw in all four screws tightly.
      • Spin in clockwise direction to tighten.
      • Screw in opposing screws first to keep them in place.
      Ask FixBot
Fatima Ruiz Ruiz
193 Reputation
1 Guide authored
UC Davis, Team 3-4, Andersen Winter 2024 Member of UC Davis, Team 3-4, Andersen Winter 2024
UCD-ANDERSEN-W24S3G4
3 Members
12 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 37
All Time: 682
