Up to 20% off select tools
Kitchen Drawer Rear Mounts Replacement
Views: 5.2K
View statistics:
Past 24 Hours:
3
Past 7 Days:
35
Past 30 Days:
188
All Time:
5,193
Comments: 1
1 comment on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 35 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
In this guide, I will demonstrate how to replace their broken kitchen drawer mounts. This issue can be very common if drawers were not built with quality material when building the house. To get the material needed you can take in your broken track or mount into a hardware store and find the correct size. This is a quick and easy repair that will take little time and basic knowledge of repairs/tools.
    1. Kitchen Drawer Rear Mounts Replacement, Rear drawer mounts: step 1, image 1 of 2 Kitchen Drawer Rear Mounts Replacement, Rear drawer mounts: step 1, image 2 of 2
      • Remove all utensils from the drawer and remove the drawer from the slot.
      Ask FixBot
    2. Kitchen Drawer Rear Mounts Replacement: step 2, image 1 of 2 Kitchen Drawer Rear Mounts Replacement: step 2, image 2 of 2
      • Start removing the mounts and tracks by unscrewing them with your drill or screwdriver.
      • Your replacement tracks or mounts will come with new screws.
      Ask FixBot
    3. Kitchen Drawer Rear Mounts Replacement: step 3, image 1 of 1
      • Once you have all your new material, insert the mounts onto your track.
      Ask FixBot
    4. Kitchen Drawer Rear Mounts Replacement: step 4, image 1 of 1
      • Take the track with the new mount attached and screw it into the existing hole using the new screws that came in the packaging.
      Ask FixBot
    5. Kitchen Drawer Rear Mounts Replacement: step 5, image 1 of 2 Kitchen Drawer Rear Mounts Replacement: step 5, image 2 of 2
      • After the track has one screw drilled, use a level to make sure your track is straight.
      • Depending on your new mounts, you may or may not need to drill new holes for the screws. If you do need to drill new holes mark the holes on the mount with a pencil or marker.
      Ask FixBot
    6. Kitchen Drawer Rear Mounts Replacement: step 6, image 1 of 1
      • Drill the screws in either the existing holes or marked spots to hold the mount in place.
      Ask FixBot
    7. Kitchen Drawer Rear Mounts Replacement: step 7, image 1 of 1
      • Repeat these steps on the other side if needed.
      Ask FixBot
    8. Kitchen Drawer Rear Mounts Replacement: step 8, image 1 of 1
      • Place your drawer back into its place and you are now done with your repair!
      Ask FixBot
Now that your repair is done make sure your drawer is sliding smoothly if not you will need to remove it and clean the tracks. Another thing to look for is if the tracks are perfectly aligned if not you can go back in and fix them by following the same steps again.
Author
with
Valeria Covarrubias
182 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 35
Past 30 Days: 188
All Time: 5,193
