Introduction
The drill press spindle turns inside the quill using several bearings. After a lot of use, these bearings can wear out and need to be replaced.
This guide will show you how to replace those bearings.
Remove the chuck from the spindle and support the quill to prevent it from dropping uncontrollably when the spring tension is released.
Remove the 3 bolts that hold the spring cover in place and remove the cover.
Turn the spring lock screw left to release the spring tension.
Pull out the feed lever pinion.
Remove the supports and remove the quill from the drill press frame.
Remove the snap ring holding the top bearing in place.
Use the press to press the spindle from the quill.
The bearings are press fit into the quill, remove the bearings with the bearing removal tool.
The bottom bearings consists of a thrust bearing on top of "regular" deep groove ball bearing.
Clean the quill and insert the thrust bearing.
Press in the bottom bearing on top of the thrust bearing.
Next, press in the top bearing.
Slide the spindle back into the quill.
Use the press to press the spindle fully into the quill. Make sure the top bearing is not pressed out again by supporting it from beneath.
Add the snap ring back on top of the quill.
Insert the quill back into the frame.
While pushing and holding the quill up, slide the feed lever pinion back in connecting with the quill rack.
Insert the end of the pinion into the spiral spring.
Complete the repair by tensioning the spring. Refer to the separate guide for detailed instructions.
