Kinivo ZX100 Mini Portable Speaker LED Indicator Replacement
  1. Kinivo ZX100 Mini Portable Speaker LED Indicator Replacement, Disassembling Kinivo ZX100 Mini Portable Speaker: step 1, image 1 of 1
    • Open the circular portion at the top of the speaker by twisting it until it reaches the maximum possible height.
    • Make sure it is twisted fully, as this will allow access to four screws to be removed in the next step.
    Ask FixBot
  2. Kinivo ZX100 Mini Portable Speaker LED Indicator Replacement: step 2, image 1 of 2 Kinivo ZX100 Mini Portable Speaker LED Indicator Replacement: step 2, image 2 of 2
    • Remove the four 12 mm Phillips screws from the enclosure.
    Ask FixBot
  3. Kinivo ZX100 Mini Portable Speaker LED Indicator Replacement: step 3, image 1 of 2 Kinivo ZX100 Mini Portable Speaker LED Indicator Replacement: step 3, image 2 of 2
    • Separate the resonator portion from the base of device to reveal the middle separator of the enclosure. The enclosure will now be in two pieces.
    • Hold the resonator portion of the enclosure gently aside to make sure there is no tension on the black and red wires coming from the bottom portion of the device.
    • Excessive force may disconnect the black and red speaker wires from the circuitry in the bottom portion of the device.
    Ask FixBot
  4. Kinivo ZX100 Mini Portable Speaker LED Indicator Replacement: step 4, image 1 of 1
    • Separate the very bottom portion of the enclosure (marked in red) by pulling vertically on the red portion of the enclosure (marked in orange).
    • Gently set the very bottom portion and the resonator section aside once they have both been separated.
    • Remove the circuit board with your hands by lifting and sliding the board away from the LED indicator.
    Ask FixBot
  5. Kinivo ZX100 Mini Portable Speaker LED Indicator Replacement, LED Indicator: step 5, image 1 of 1
    • LED Locating
    • Locate the three, metal prongs found near the edge of the circuit board. They are found directly behind the LED light.
    Ask FixBot
    • Soldering
    • If you are not familiar with the process of soldering, please refer to an online manual.
    • Heat the soldering iron to operating temperature.
    • Avoid touching the heated tip of the iron to ensure that you do not burn yourself.
    Ask FixBot
  6. Kinivo ZX100 Mini Portable Speaker LED Indicator Replacement: step 7, image 1 of 2 Kinivo ZX100 Mini Portable Speaker LED Indicator Replacement: step 7, image 2 of 2
    Tool used on this step:
    Buy
    • Prong Removal
    • The picture in this step calls for speaker wire, but it can also be applied for the removal of each prong.
    • Remove a single prong by pulling it directly up from the circuit board using tweezers.
    • Repeat the previous until all three prongs have been removed.
    Ask FixBot
  7. Kinivo ZX100 Mini Portable Speaker LED Indicator Replacement: step 8, image 1 of 1
    • Replacement
    • Obtain a new LED component from a manufacturer.
    • Perform the steps in reverse order to reconnect the new LED to the circuit board.
    Ask FixBot
2 other people completed this guide.
Matthew Kotce
266 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 17
All Time: 591
