Kingston HyperX CloudX Ear Pads Replacement
  1. Kingston HyperX CloudX Ear Pads Replacement, Ear Pads: step 1, image 1 of 1
    • Place one finger on the inside of the cushion and place the other finger on the outer rim of the ear pad cushion.
    • Gently pull the ear pad away from the headset, removing the flap from the groove until the old ear pads are fully detached.
    Ask FixBot
  2. Kingston HyperX CloudX Ear Pads Replacement: step 2, image 1 of 1
    • Take the new ear pad and slide the top side of the flap into the groove of the ear cup.
    • Once the flap is inside the groove, slide it all the way in to make sure the flap is secured inside the groove.
    Ask FixBot
  3. Kingston HyperX CloudX Ear Pads Replacement: step 3, image 1 of 1
    • Squeeze the top part of the cushion into the earcup to keep it secure and prevent the flap from sliding out of the groove.
    • Make sure to keep a tight squeeze onto the cushion until it is fully secured onto the earcup to prevent the flap from slipping out.
    Ask FixBot
  4. Kingston HyperX CloudX Ear Pads Replacement: step 4, image 1 of 1
    • Slowly start going around the outside of the earcup and stretching the cushion so that the flap is secured into the groove.
    Ask FixBot
  5. Kingston HyperX CloudX Ear Pads Replacement: step 5, image 1 of 2 Kingston HyperX CloudX Ear Pads Replacement: step 5, image 2 of 2
    • Push the flap further into the groove by taking a spudger and going around the outside of the headset slowly pushing the spudger into the groove to make sure the flap is fully secured into the groove.
    • If you do not have a spudger, you can also use a credit card instead.
    Ask FixBot
  6. Kingston HyperX CloudX Ear Pads Replacement: step 6, image 1 of 1
    • Squeeze the ear cushion and move it slightly back and forth to ensure the flap is secured.
    • Repeat on the other side.
    Ask FixBot
Finish Line
Sam Bloch
133 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 9
Past 30 Days: 68
All Time: 1,464
