Introduction
If you are unable to connect to the internet with your Voyage there is likely a problem with your WiFi antenna. This guide is here to help you locate and remove it.
Insert a plastic opening tool between the plastic panel shown on the device.
Use the tool to pry the plastic away from the device.
Use an aluminum driver with Phillips head #00 to remove the four 3 mm screws shown in the picture.
Use the same driver to remove the two 2.5 mm screws.
1 Guide Comment
Re Kindle Voyage Wifi Antenna Replacement guide: I cannot find the WiFi antenna bar on your website to purchase a replacement. Do you sell it?
