Up to 20% off select tools
Kindle Voyage Battery Replacement
Views: 42K
View statistics:
Past 24 Hours:
18
Past 7 Days:
149
Past 30 Days:
590
All Time:
41,940
Comments: 46
27 comments on steps, 19 guide comments.
Go to guide comments
Completed: 40
40 people have marked this guide "completed." Will you be next?
Favorites: 5
5 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 2 minutes
Difficulty: Easy
Parts
Tools
Introduction
Go to step 1 ↓
The battery, like most batteries, gives juice to the device. This guide will show you how to carefully remove it for troubleshooting purposes.
    1. Kindle Voyage Battery Replacement, Back Panel: step 1, image 1 of 2 Kindle Voyage Battery Replacement, Back Panel: step 1, image 2 of 2
      • Insert a plastic opening tool between the plastic panel shown on the device.
      • Use the tool to pry the plastic away from the device.
      • There will be adhesive holding this piece of plastic to the device. You may have to pull pretty hard to get it separated.
      Ask FixBot
    2. Kindle Voyage Battery Replacement: step 2, image 1 of 1
      • Use an aluminum driver attached with a Phillips head size #00 to remove the four 3mm screws shown in the picture. For reassembly, note that the top two and bottom two screws are different sizes.
      Ask FixBot
    3. Kindle Voyage Battery Replacement: step 3, image 1 of 3 Kindle Voyage Battery Replacement: step 3, image 2 of 3 Kindle Voyage Battery Replacement: step 3, image 3 of 3
      • Once the screws are removed, the back panel can slide off the device.
      Ask FixBot
    4. Kindle Voyage Battery Replacement: step 4, image 1 of 2 Kindle Voyage Battery Replacement: step 4, image 2 of 2
      • Remove the magnetic component with the magnetic head of the aluminum driver.
      Ask FixBot
    1. Kindle Voyage Battery Replacement, Battery: step 5, image 1 of 2 Kindle Voyage Battery Replacement, Battery: step 5, image 2 of 2
      Tool used on this step:
      Plastic Cards
      $2.99
      Buy
      • Use a plastic card to pry the battery away from the device.
      • Gently un-clip the battery plug from the device and remove the battery.
      Ask FixBot
40 other people completed this guide.
Author
with
Sean Yap
1,528 Reputation
6 Guides authored
Cal Poly, Team 19-12, Maness Winter 2015 Member of Cal Poly, Team 19-12, Maness Winter 2015
CPSU-MANESS-W15S19G12
5 Members
72 Guides authored
19 Guide Comments
Where can I buy a replacement buttery for my kindle voyage?
hegi88 - Reply Share
Where to find a replacement battery for kindle voyage 3G please if any one knows
Himadri Endow - Reply Share
Bump. Cannot seem to procure a new battery for the Kindle Voyage. Nice to know how to replace the old one; just need something to replace it WITH! Thanks for any hints on finding one. Battery model number is: MC-305070, 3.8V 1320mAh/5.01Wh, P/N 58-000056
larryg - Reply Share
Any advance on where one can find a replacement battery for the Kindle Journal?
Charles WRIGHT - Reply Share
Still looking for a source for this battery.
Neil Hall - Reply Share
Past 24 Hours: 18
Past 7 Days: 149
Past 30 Days: 590
All Time: 41,940
