Kindle Touch Speaker Replacement
    1. Kindle Touch Speaker Replacement, Back Cover: step 1, image 1 of 3 Kindle Touch Speaker Replacement, Back Cover: step 1, image 2 of 3 Kindle Touch Speaker Replacement, Back Cover: step 1, image 3 of 3
      • Use the plastic opening tool to undo the six plastic clips around the bottom of the back panel of the Kindle.
      • Don't pry the clips on the top half of the back panel.
      Ask FixBot
    2. Kindle Touch Speaker Replacement: step 2, image 1 of 2 Kindle Touch Speaker Replacement: step 2, image 2 of 2
      • Slide the back panel downward, toward the charging port. This will release the clips on the top half.
      • Once the top clips release, gently lift the back panel away.
      Ask FixBot
    1. Kindle Touch Speaker Replacement, Battery: step 3, image 1 of 3 Kindle Touch Speaker Replacement, Battery: step 3, image 2 of 3 Kindle Touch Speaker Replacement, Battery: step 3, image 3 of 3
      • Use a Phillips #00 screwdriver to remove the five screws.
      Ask FixBot
    2. Kindle Touch Speaker Replacement: step 4, image 1 of 3 Kindle Touch Speaker Replacement: step 4, image 2 of 3 Kindle Touch Speaker Replacement: step 4, image 3 of 3
      • Using the flat end of your spudger, gently pry the battery up and remove it.
      Ask FixBot
    1. Kindle Touch Speaker Replacement, Bezel: step 5, image 1 of 2 Kindle Touch Speaker Replacement, Bezel: step 5, image 2 of 2
      • Using a Phillips #00 screwdriver, remove the six 4 mm screws to access the front plate.
      Ask FixBot
    2. Kindle Touch Speaker Replacement: step 6, image 1 of 3 Kindle Touch Speaker Replacement: step 6, image 2 of 3 Kindle Touch Speaker Replacement: step 6, image 3 of 3
      • Use the plastic opening tool to pry the bezel from the top and sides
      • The bottom of the bezel will be glued, so be careful when sliding the clips out.
      • The clips can be easily bent, so do not try to force them out. If you do bend some, they can be bent back.
      Ask FixBot
    1. Kindle Touch Speaker Replacement, Rear Casing: step 7, image 1 of 1
      • Use your Phillips #00 srewdriver to remove the indicated screws.
      • There are three pairs of screws that are each different. The screws on the top corners are 4 mm #00 Phillips screws, the screws on the bottom corners are 2 mm #00 Phillips screws, and the black bottom center screws are 6 mm #00 Phillips screws.
      Ask FixBot
    2. Kindle Touch Speaker Replacement: step 8, image 1 of 2 Kindle Touch Speaker Replacement: step 8, image 2 of 2
      • With the screws removed, gently remove the case from the internals.
      Ask FixBot
    1. Kindle Touch Speaker Replacement, Speaker: step 9, image 1 of 3 Kindle Touch Speaker Replacement, Speaker: step 9, image 2 of 3 Kindle Touch Speaker Replacement, Speaker: step 9, image 3 of 3
      • Use the pointy end of your Spudger to separate the Speaker's connector from the motherboard on both sides.
      Ask FixBot
    2. Kindle Touch Speaker Replacement: step 10, image 1 of 3 Kindle Touch Speaker Replacement: step 10, image 2 of 3 Kindle Touch Speaker Replacement: step 10, image 3 of 3
      • The speakers are held down solely with contact adhesive, so use your Spudger to pry them from the support board.
      Ask FixBot
Adam Yerly
2,043 Reputation
7 Guides authored
USF Tampa, Team 19-5, Blackwell Winter 2015 Member of USF Tampa, Team 19-5, Blackwell Winter 2015
USFT-BLACKWELL-W15S19G5
3 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 35
All Time: 1,595
