Up to 20% off select tools
Kindle Touch Screen Replacement
Views: 12K
View statistics:
Past 24 Hours:
9
Past 7 Days:
46
Past 30 Days:
183
All Time:
11,931
Comments: 10
4 comments on steps, 6 guide comments.
Go to guide comments
Completed: 10
10 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 20 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
Use this guide to separate the screen from the screen support unit.
    1. Kindle Touch Screen Replacement, Back Cover: step 1, image 1 of 3 Kindle Touch Screen Replacement, Back Cover: step 1, image 2 of 3 Kindle Touch Screen Replacement, Back Cover: step 1, image 3 of 3
      • Use the plastic opening tool to undo the six plastic clips around the bottom of the back panel of the Kindle.
      • Don't pry the clips on the top half of the back panel.
      Ask FixBot
    2. Kindle Touch Screen Replacement: step 2, image 1 of 2 Kindle Touch Screen Replacement: step 2, image 2 of 2
      • Slide the back panel downward, toward the charging port. This will release the clips on the top half.
      • Once the top clips release, gently lift the back panel away.
      Ask FixBot
    1. Kindle Touch Screen Replacement, Battery: step 3, image 1 of 3 Kindle Touch Screen Replacement, Battery: step 3, image 2 of 3 Kindle Touch Screen Replacement, Battery: step 3, image 3 of 3
      • Use a Phillips #00 screwdriver to remove the five screws.
      Ask FixBot
    2. Kindle Touch Screen Replacement: step 4, image 1 of 3 Kindle Touch Screen Replacement: step 4, image 2 of 3 Kindle Touch Screen Replacement: step 4, image 3 of 3
      • Using the flat end of your spudger, gently pry the battery up and remove it.
      Ask FixBot
    1. Kindle Touch Screen Replacement, Remove the 3G Board: step 5, image 1 of 3 Kindle Touch Screen Replacement, Remove the 3G Board: step 5, image 2 of 3 Kindle Touch Screen Replacement, Remove the 3G Board: step 5, image 3 of 3
      • Remove the indicated four 2 mm screws with a Phillips #00 screwdriver. (Units with the 3G assembly have Phillips #000 screws.)
      • Next, gently lift the 3G assembly with a Spudger or your fingers.
      • This Kindle Touch is the WiFi only model and comes with a plastic placeholder instead of the 3G assembly.
      • Disconnect the antenna lead by carefully prying it off the 3G board with a plastic tool.
      Ask FixBot
    1. Kindle Touch Screen Replacement, Bezel: step 6, image 1 of 2 Kindle Touch Screen Replacement, Bezel: step 6, image 2 of 2
      • Using a Phillips #00 screwdriver, remove the six 4 mm screws to access the front plate.
      Ask FixBot
    2. Kindle Touch Screen Replacement: step 7, image 1 of 3 Kindle Touch Screen Replacement: step 7, image 2 of 3 Kindle Touch Screen Replacement: step 7, image 3 of 3
      • Use the plastic opening tool to pry the bezel from the top and sides
      • The bottom of the bezel will be glued, so be careful when sliding the clips out.
      • The clips can be easily bent, so do not try to force them out. If you do bend some, they can be bent back.
      Ask FixBot
    1. Kindle Touch Screen Replacement, Rear Casing: step 8, image 1 of 1
      • Use your Phillips #00 srewdriver to remove the indicated screws.
      • There are three pairs of screws that are each different. The screws on the top corners are 4 mm #00 Phillips screws, the screws on the bottom corners are 2 mm #00 Phillips screws, and the black bottom center screws are 6 mm #00 Phillips screws.
      Ask FixBot
    2. Kindle Touch Screen Replacement: step 9, image 1 of 2 Kindle Touch Screen Replacement: step 9, image 2 of 2
      • With the screws removed, gently remove the case from the internals.
      Ask FixBot
    1. Kindle Touch Screen Replacement, Motherboard: step 10, image 1 of 3 Kindle Touch Screen Replacement, Motherboard: step 10, image 2 of 3 Kindle Touch Screen Replacement, Motherboard: step 10, image 3 of 3
      • With the screen facing you, use your heated iOpener or other heating element to loosen the glue holding the WiFi unit to the screen. After 30 seconds, remove the heating element.
      • After the glue is loosened, use a thin tool, like a Spudger or small plastic opening tool, to separate the WiFi unit from the screen.
      Ask FixBot
    2. Kindle Touch Screen Replacement: step 11, image 1 of 2 Kindle Touch Screen Replacement: step 11, image 2 of 2
      • With the motherboard facing you, use the pointy end of your Spudger to gently separate the two speaker's connectors.
      • This connector type requires being lifted out of place, not pulled. Accidentally pulling may damage the wires.
      • During reassembly, make sure the speaker's connectors are not pushed behind the motherboard.
      • Use your #00 Phillips Screwdriver to remove the seven 2 mm screws.
      Ask FixBot
    3. Kindle Touch Screen Replacement: step 12, image 1 of 3 Kindle Touch Screen Replacement: step 12, image 2 of 3 Kindle Touch Screen Replacement: step 12, image 3 of 3
      • Use a Spudger to separate the display's connector from the motherboard.
      • Gently remove the motherboard from the display support.
      Ask FixBot
    1. Kindle Touch Screen Replacement, Screen: step 13, image 1 of 3 Kindle Touch Screen Replacement, Screen: step 13, image 2 of 3 Kindle Touch Screen Replacement, Screen: step 13, image 3 of 3
      • Using your Metal Spudger, place the pointy end into the top of the clip.
      • Gently rotate the Spudger and lift the plastic unit to create a gap on the side.
      Ask FixBot
    2. Kindle Touch Screen Replacement: step 14, image 1 of 2 Kindle Touch Screen Replacement: step 14, image 2 of 2
      • Use the Spudger in the gap to pry the clip open.
      • Repeat for the other clips.
      Ask FixBot
    3. Kindle Touch Screen Replacement: step 15, image 1 of 3 Kindle Touch Screen Replacement: step 15, image 2 of 3 Kindle Touch Screen Replacement: step 15, image 3 of 3
      • With the clips separated, gently guide the Screen's Motherboard Connector through the hole.
      Ask FixBot
10 other people completed this guide.
Author
with
Adam Yerly
2,043 Reputation
7 Guides authored
USF Tampa, Team 19-5, Blackwell Winter 2015 Member of USF Tampa, Team 19-5, Blackwell Winter 2015
USFT-BLACKWELL-W15S19G5
3 Members
96 Guides authored
6 Guide Comments
I would love to know where I can get the replacement screen. Any links?
Ryan Lee - Reply Share
Good guide, thanks, finally, if you need to remove the screen itself from the black plastic frame you can do this inserting the spudger carefully between the screen and the black plastic frame and gradually moving it all round the frame. It will help if you put a heated silicon gel pack over each side before trying to release it
John Chapple - Reply Share
I have a Kindle with half of screen responding to touch
Is the touch incliduded on the screen itself? Will replacing the screen help or is there another way to fix the touch?
Mohd. Nauman Khalid - Reply Share
No, the touch circuitry is built into the motherboard.
Chris Halliwell - Reply Share
Where do you buy the screen replacement part for the Kindle Touch?
Andrew Manger - Reply Share
Past 24 Hours: 9
Past 7 Days: 46
Past 30 Days: 183
All Time: 11,931
