Up to 20% off select tools
Kindle Touch Bezel Replacement
Views: 4.3K
View statistics:
Past 24 Hours:
3
Past 7 Days:
30
Past 30 Days:
123
All Time:
4,336
Comments: 4
3 comments on steps, 1 guide comment.
Go to guide comments
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
This guide will cover how to remove and replace the bezel on a Kindle Touch and requires using a plastic opening tool and PH00 screwdriver.
    1. Kindle Touch Bezel Replacement, Back Cover: step 1, image 1 of 3 Kindle Touch Bezel Replacement, Back Cover: step 1, image 2 of 3 Kindle Touch Bezel Replacement, Back Cover: step 1, image 3 of 3
      • Use the plastic opening tool to undo the six plastic clips around the bottom of the back panel of the Kindle.
      • Don't pry the clips on the top half of the back panel.
      Ask FixBot
    2. Kindle Touch Bezel Replacement: step 2, image 1 of 2 Kindle Touch Bezel Replacement: step 2, image 2 of 2
      • Slide the back panel downward, toward the charging port. This will release the clips on the top half.
      • Once the top clips release, gently lift the back panel away.
      Ask FixBot
    1. Kindle Touch Bezel Replacement, Bezel: step 3, image 1 of 2 Kindle Touch Bezel Replacement, Bezel: step 3, image 2 of 2
      • Using a Phillips #00 screwdriver, remove the six 4 mm screws to access the front plate.
      Ask FixBot
    2. Kindle Touch Bezel Replacement: step 4, image 1 of 3 Kindle Touch Bezel Replacement: step 4, image 2 of 3 Kindle Touch Bezel Replacement: step 4, image 3 of 3
      • Use the plastic opening tool to pry the bezel from the top and sides
      • The bottom of the bezel will be glued, so be careful when sliding the clips out.
      • The clips can be easily bent, so do not try to force them out. If you do bend some, they can be bent back.
      Ask FixBot
4 other people completed this guide.
Author
with
Jerome Narine
224 Reputation
1 Guide authored
USF Tampa, Team 19-5, Blackwell Winter 2015 Member of USF Tampa, Team 19-5, Blackwell Winter 2015
USFT-BLACKWELL-W15S19G5
3 Members
96 Guides authored
1 Guide Comment
I want to paint The bezel white. Will it come back and fit perfectly after the removal I have to make?
denianyc - Reply Share
Past 24 Hours: 3
Past 7 Days: 30
Past 30 Days: 123
All Time: 4,336
