Up to 20% off select tools
Kindle Touch Battery Replacement
Views: 15K
View statistics:
Past 24 Hours:
10
Past 7 Days:
59
Past 30 Days:
290
All Time:
14,670
Comments: 5
3 comments on steps, 2 guide comments.
Go to guide comments
Completed: 22
22 people have marked this guide "completed." Will you be next?
Favorites: 4
4 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
Use this guide to replace an old or faulty Amazon Kindle Touch battery. The battery may be due for replacement if your Kindle runs out of power quickly, won’t work unless plugged in, or won’t charge.
Make sure the device is powered off and disconnected from all external power sources before beginning this process. Please dispose of electronic waste responsibly.
    1. Kindle Touch Battery Replacement, Back Cover: step 1, image 1 of 3 Kindle Touch Battery Replacement, Back Cover: step 1, image 2 of 3 Kindle Touch Battery Replacement, Back Cover: step 1, image 3 of 3
      • Use the plastic opening tool to undo the six plastic clips around the bottom of the back panel of the Kindle.
      • Don't pry the clips on the top half of the back panel.
      Ask FixBot
    2. Kindle Touch Battery Replacement: step 2, image 1 of 2 Kindle Touch Battery Replacement: step 2, image 2 of 2
      • Slide the back panel downward, toward the charging port. This will release the clips on the top half.
      • Once the top clips release, gently lift the back panel away.
      Ask FixBot
    1. Kindle Touch Battery Replacement, Battery: step 3, image 1 of 3 Kindle Touch Battery Replacement, Battery: step 3, image 2 of 3 Kindle Touch Battery Replacement, Battery: step 3, image 3 of 3
      • Use a Phillips #00 screwdriver to remove the five screws.
      Ask FixBot
    2. Kindle Touch Battery Replacement: step 4, image 1 of 3 Kindle Touch Battery Replacement: step 4, image 2 of 3 Kindle Touch Battery Replacement: step 4, image 3 of 3
      • Using the flat end of your spudger, gently pry the battery up and remove it.
      Ask FixBot
22 other people completed this guide.
Author
with
Adam Yerly
2,043 Reputation
7 Guides authored
USF Tampa, Team 19-5, Blackwell Winter 2015 Member of USF Tampa, Team 19-5, Blackwell Winter 2015
USFT-BLACKWELL-W15S19G5
3 Members
96 Guides authored
2 Guide Comments
Where can I buy a new battery?
Carla Grobler (Ubbink) - Reply Share
I tried this, but my Kindle still wouldn't work so it must not have been the battery. I'm happy to mail the new battery and the tools that came with it to whoever needs them if shipping isn't too expensive from California. Reach me at meldmb9-at-hotmail-dot-com subject line "kindle battery".
TryingToFix - Reply Share
Past 24 Hours: 10
Past 7 Days: 59
Past 30 Days: 290
All Time: 14,670
