Kindle Touch 3G Card Housing Replacement
Views: 3.3K
View statistics:
Past 24 Hours:
5
Past 7 Days:
23
Past 30 Days:
95
All Time:
3,267
Comments: 6
4 comments on steps, 2 guide comments.
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
Next to the battery is the 3G unit. However, in the
models that are WiFi only, there will instead be a plastic placeholder instead. The replacement instructions for both are identical.
Tools
Video Overview
    1. Kindle Touch 3G Card Housing Replacement, Back Cover: step 1, image 1 of 3 Kindle Touch 3G Card Housing Replacement, Back Cover: step 1, image 2 of 3 Kindle Touch 3G Card Housing Replacement, Back Cover: step 1, image 3 of 3
      • Use the plastic opening tool to undo the six plastic clips around the bottom of the back panel of the Kindle.
      • Don't pry the clips on the top half of the back panel.
      Ask FixBot
    2. Kindle Touch 3G Card Housing Replacement: step 2, image 1 of 2 Kindle Touch 3G Card Housing Replacement: step 2, image 2 of 2
      • Slide the back panel downward, toward the charging port. This will release the clips on the top half.
      • Once the top clips release, gently lift the back panel away.
      Ask FixBot
    1. Kindle Touch 3G Card Housing Replacement, Battery: step 3, image 1 of 3 Kindle Touch 3G Card Housing Replacement, Battery: step 3, image 2 of 3 Kindle Touch 3G Card Housing Replacement, Battery: step 3, image 3 of 3
      • Use a Phillips #00 screwdriver to remove the five screws.
      Ask FixBot
    2. Kindle Touch 3G Card Housing Replacement: step 4, image 1 of 3 Kindle Touch 3G Card Housing Replacement: step 4, image 2 of 3 Kindle Touch 3G Card Housing Replacement: step 4, image 3 of 3
      • Using the flat end of your spudger, gently pry the battery up and remove it.
      Ask FixBot
    1. Kindle Touch 3G Card Housing Replacement, Remove the 3G Board: step 5, image 1 of 3 Kindle Touch 3G Card Housing Replacement, Remove the 3G Board: step 5, image 2 of 3 Kindle Touch 3G Card Housing Replacement, Remove the 3G Board: step 5, image 3 of 3
      • Remove the indicated four 2 mm screws with a Phillips #00 screwdriver. (Units with the 3G assembly have Phillips #000 screws.)
      • Next, gently lift the 3G assembly with a Spudger or your fingers.
      • This Kindle Touch is the WiFi only model and comes with a plastic placeholder instead of the 3G assembly.
      • Disconnect the antenna lead by carefully prying it off the 3G board with a plastic tool.
      Ask FixBot
3 other people completed this guide.
Adam Yerly
2,043 Reputation
7 Guides authored
USF Tampa, Team 19-5, Blackwell Winter 2015 Member of USF Tampa, Team 19-5, Blackwell Winter 2015
USFT-BLACKWELL-W15S19G5
3 Members
96 Guides authored
2 Guide Comments
Hey, thanks for your guide!
I, however, have one question, maybe I misunderstood - is it possible to add a 3G module to a kindle touch that didn't have one installed by default?
Would it work?
Curious_Guy_Threepwood - Reply Share
You would need to add more than just a 3G module - there’s a slot for a SIM-card tray and special Amazon SIM that are missing from non-3G Kindle Touches. I don’t know if there would be any software changes that would need making.
Darren John de Lima - Reply Share
Past 24 Hours: 5
Past 7 Days: 23
Past 30 Days: 95
All Time: 3,267
