Up to 20% off select tools
Kindle Paperwhite 3rd Generation Screen/Display Touch Panel Replacement
Views: 60K
View statistics:
Past 24 Hours:
7
Past 7 Days:
71
Past 30 Days:
364
All Time:
59,786
Comments: 34
19 comments on steps, 15 guide comments.
Go to guide comments
Completed: 20
20 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 - 20 minutes
Difficulty: Moderate
Parts
Tools
Introduction
Go to step 1 ↓
Amazon’s Kindle Paperwhite 3rd Generation possesses a six inch, 300 PPI display. This guide requires that the Kindle is turned off, and that a plastic opening tool, angled precision tweezers, and a PH000 screwdriver are used.
    1. Kindle Paperwhite 3rd Generation Screen/Display Touch Panel Replacement, Battery: step 1, image 1 of 3 Kindle Paperwhite 3rd Generation Screen/Display Touch Panel Replacement, Battery: step 1, image 2 of 3 Kindle Paperwhite 3rd Generation Screen/Display Touch Panel Replacement, Battery: step 1, image 3 of 3
      • Ensure that the device is turned off before beginning.
      • Gently pry the bezel off the screen using a plastic opening tool. Start at the corners and slide around the edges until you return to your starting point.
      • Be careful if using the metal spudger, as it can scratch the surface of the Kindle.
      Ask FixBot
    2. Kindle Paperwhite 3rd Generation Screen/Display Touch Panel Replacement, Using caution: step 2, image 1 of 3 Kindle Paperwhite 3rd Generation Screen/Display Touch Panel Replacement, Using caution: step 2, image 2 of 3 Kindle Paperwhite 3rd Generation Screen/Display Touch Panel Replacement, Using caution: step 2, image 3 of 3
      • Use extreme caution when prying up the bezel. Be careful not to allow your pry tool to fall underneath the display. Look under the cover as you work, separating the display from the adhesive of the bezel.
      • You want to make sure your separator goes through both sides of the bezel over top of the display.
      • The second photo is the layer you want your tool to pass through safely.
      • The third photo is an example of what can go wrong. If this happens your digitizer layer will misread touches and the display is permanently damaged.
      Ask FixBot
    3. Kindle Paperwhite 3rd Generation Screen/Display Touch Panel Replacement: step 3, image 1 of 2 Kindle Paperwhite 3rd Generation Screen/Display Touch Panel Replacement: step 3, image 2 of 2
      • Unscrew the eleven 3.2 mm Phillips #000 screws surrounding the frame.
      Ask FixBot
    4. Kindle Paperwhite 3rd Generation Screen/Display Touch Panel Replacement: step 4, image 1 of 1
      • Gently lift the mid-frame out of the case with your hands.
      • Lift the side opposite of the power button out first.
      Ask FixBot
    5. Kindle Paperwhite 3rd Generation Screen/Display Touch Panel Replacement: step 5, image 1 of 2 Kindle Paperwhite 3rd Generation Screen/Display Touch Panel Replacement: step 5, image 2 of 2
      • Unscrew the three 3.0 mm Phillips #000 screws that are securing the battery.
      Ask FixBot
    6. Kindle Paperwhite 3rd Generation Screen/Display Touch Panel Replacement: step 6, image 1 of 1
      • Gently lift the battery from the frame.
      Ask FixBot
    1. Kindle Paperwhite 3rd Generation Screen/Display Touch Panel Replacement, Motherboard: step 7, image 1 of 1
      • Flip the black latch with a plastic opening tool, and then gently pull back the orange ribbon cable.
      Ask FixBot
    2. Kindle Paperwhite 3rd Generation Screen/Display Touch Panel Replacement: step 8, image 1 of 1
      Tool used on this step:
      Buy
      • Flip the tiny off-white latch with angled precision tweezers toward the direction of the battery.
      • Gently peel back the orange ribbon cable.
      Ask FixBot
    3. Kindle Paperwhite 3rd Generation Screen/Display Touch Panel Replacement: step 9, image 1 of 2 Kindle Paperwhite 3rd Generation Screen/Display Touch Panel Replacement: step 9, image 2 of 2
      • Peel back the orange ribbon cable near the battery.
      • Flip the tiny black latch with angled precision tweezers toward the closest edge of the device.
      Ask FixBot
    4. Kindle Paperwhite 3rd Generation Screen/Display Touch Panel Replacement: step 10, image 1 of 1
      • Peel back the white connector with your fingers.
      Ask FixBot
    5. Kindle Paperwhite 3rd Generation Screen/Display Touch Panel Replacement: step 11, image 1 of 2 Kindle Paperwhite 3rd Generation Screen/Display Touch Panel Replacement: step 11, image 2 of 2
      • Unscrew the six 3.0 mm Phillips #000 screws surrounding the motherboard.
      • Unscrew the one 2.5 mm Phillips #000 screw.
      • There is a little metal plate underneath the 2.5 mm screw and washers under four of the 3.0 mm screws.
      Ask FixBot
    6. Kindle Paperwhite 3rd Generation Screen/Display Touch Panel Replacement: step 12, image 1 of 1
      • Use a plastic opening tool to lift the motherboard upwards from the frame.
      Ask FixBot
    1. Kindle Paperwhite 3rd Generation Screen/Display Touch Panel Replacement, Screen/Display Touch Panel: step 13, image 1 of 1
      • The touchscreen is attached to the rest of the frame. Purchasing a new frame will require reattaching the motherboard and the battery.
      Ask FixBot
20 other people completed this guide.
Author
with
Micah Smart
3,435 Reputation
3 Guides authored
USF Tampa, Team 14-3, Lacy Spring 2016 Member of USF Tampa, Team 14-3, Lacy Spring 2016
USFT-LACY-S16S14G3
4 Members
36 Guides authored
15 Guide Comments
hi there thank youfor your helping tutorial.
i just bought some used Kindle in order to buy at my shop. but i have a problem with some Kindle that i disassembled in order to have some spare parts and especially with the screen.
even after removing the screen it will stay frozen, even if i change the motherboard with a new one it will stay on the last screen shown.
Might you give me any explanation about the issue? and is that a way to reset the screen in order to use it as spare parts for other kindles?
charbel - Reply Share
Thank you so much for this tutorial! Thanks to it I was able to replace a (physically) broken display. I un-assembled the entire device, let it rest until the shipment from China arrived and re-assembled it. It works flawlessly again and looks like new. One word of caution, though: The new display came without frame and removing the old display from the frame (both are pretty tightly glued together) resulted in quite some patient work and many pieces of broken glass (even with having it all heated). Anyway it worked out like a charm at the end!
Uwe Ritter - Reply Share
Hello, where I can but a replacement screen for Kindle Paperwhite 300 ppi?? Thanks!!
Andres Barrera - Reply Share
For anyone curious, the panel number for the PW3 is ED060KD1. You can use this to look it up on eBay etc.
Joshua Rong Xing Ong - Reply Share
Do you have to take the broken screen out of the frame and then put the new one in? Is it difficult?
Chris - Reply Share
Past 24 Hours: 7
Past 7 Days: 71
Past 30 Days: 364
All Time: 59,786
