Kindle Paperwhite 3rd Generation Motherboard Replacement
    1. Kindle Paperwhite 3rd Generation Motherboard Replacement, Battery: step 1, image 1 of 3 Kindle Paperwhite 3rd Generation Motherboard Replacement, Battery: step 1, image 2 of 3 Kindle Paperwhite 3rd Generation Motherboard Replacement, Battery: step 1, image 3 of 3
      • Ensure that the device is turned off before beginning.
      • Gently pry the bezel off the screen using a plastic opening tool. Start at the corners and slide around the edges until you return to your starting point.
      • Be careful if using the metal spudger, as it can scratch the surface of the Kindle.
      Ask FixBot
    2. Kindle Paperwhite 3rd Generation Motherboard Replacement, Using caution: step 2, image 1 of 3 Kindle Paperwhite 3rd Generation Motherboard Replacement, Using caution: step 2, image 2 of 3 Kindle Paperwhite 3rd Generation Motherboard Replacement, Using caution: step 2, image 3 of 3
      • Use extreme caution when prying up the bezel. Be careful not to allow your pry tool to fall underneath the display. Look under the cover as you work, separating the display from the adhesive of the bezel.
      • You want to make sure your separator goes through both sides of the bezel over top of the display.
      • The second photo is the layer you want your tool to pass through safely.
      • The third photo is an example of what can go wrong. If this happens your digitizer layer will misread touches and the display is permanently damaged.
      Ask FixBot
    3. Kindle Paperwhite 3rd Generation Motherboard Replacement: step 3, image 1 of 2 Kindle Paperwhite 3rd Generation Motherboard Replacement: step 3, image 2 of 2
      • Unscrew the eleven 3.2 mm Phillips #000 screws surrounding the frame.
      Ask FixBot
    4. Kindle Paperwhite 3rd Generation Motherboard Replacement: step 4, image 1 of 1
      • Gently lift the mid-frame out of the case with your hands.
      • Lift the side opposite of the power button out first.
      Ask FixBot
    5. Kindle Paperwhite 3rd Generation Motherboard Replacement: step 5, image 1 of 2 Kindle Paperwhite 3rd Generation Motherboard Replacement: step 5, image 2 of 2
      • Unscrew the three 3.0 mm Phillips #000 screws that are securing the battery.
      Ask FixBot
    6. Kindle Paperwhite 3rd Generation Motherboard Replacement: step 6, image 1 of 1
      • Gently lift the battery from the frame.
      Ask FixBot
    1. Kindle Paperwhite 3rd Generation Motherboard Replacement, Motherboard: step 7, image 1 of 1
      • Flip the black latch with a plastic opening tool, and then gently pull back the orange ribbon cable.
      Ask FixBot
    2. Kindle Paperwhite 3rd Generation Motherboard Replacement: step 8, image 1 of 1
      Tool used on this step:
      Buy
      • Flip the tiny off-white latch with angled precision tweezers toward the direction of the battery.
      • Gently peel back the orange ribbon cable.
      Ask FixBot
    3. Kindle Paperwhite 3rd Generation Motherboard Replacement: step 9, image 1 of 2 Kindle Paperwhite 3rd Generation Motherboard Replacement: step 9, image 2 of 2
      • Peel back the orange ribbon cable near the battery.
      • Flip the tiny black latch with angled precision tweezers toward the closest edge of the device.
      Ask FixBot
    4. Kindle Paperwhite 3rd Generation Motherboard Replacement: step 10, image 1 of 1
      • Peel back the white connector with your fingers.
      Ask FixBot
    5. Kindle Paperwhite 3rd Generation Motherboard Replacement: step 11, image 1 of 2 Kindle Paperwhite 3rd Generation Motherboard Replacement: step 11, image 2 of 2
      • Unscrew the six 3.0 mm Phillips #000 screws surrounding the motherboard.
      • Unscrew the one 2.5 mm Phillips #000 screw.
      • There is a little metal plate underneath the 2.5 mm screw and washers under four of the 3.0 mm screws.
      Ask FixBot
    6. Kindle Paperwhite 3rd Generation Motherboard Replacement: step 12, image 1 of 1
      • Use a plastic opening tool to lift the motherboard upwards from the frame.
      Ask FixBot
13 other people completed this guide.
Micah Smart
3,428 Reputation
3 Guides authored
USF Tampa, Team 14-3, Lacy Spring 2016 Member of USF Tampa, Team 14-3, Lacy Spring 2016
USFT-LACY-S16S14G3
4 Members
36 Guides authored
7 Guide Comments
how do I fix my loose charging port?
angusc - Reply Share
how do i fix my loose charging port connection
Where can I buy a kindle paper white, new mother board?
Lorraine - Reply Share
Tip, heat the front bezel to soften the glue.
KAASKOP3000 - Reply Share
I totally know how to fix my kindle but I don’t know where to get the part. I broke the tip to the ribbon cable for the only %#*@ button on the device. do they sell those here?
Corry Newton - Reply Share
Past 24 Hours: 11
Past 7 Days: 60
Past 30 Days: 269
All Time: 15,956
