Up to 20% off select tools
Kindle Paperwhite 2nd Generation Screen Replacement
Views: 16K
View statistics:
Past 24 Hours:
6
Past 7 Days:
48
Past 30 Days:
223
All Time:
16,380
Comments: 5
2 comments on steps, 3 guide comments.
Go to guide comments
Completed: 8
8 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 20 minutes
Difficulty: Easy
Parts
Tools
Introduction
Go to step 1 ↓
Disassembling a tablet often requires some gentle prying of the frame. Be sure to exercise care during these first few steps(disassembling), and do not lose your screws! The Paperwhite is a sturdy tablet that can be broken down into just a few components. This guide will show you how to replace a faulty screen.
    1. Kindle Paperwhite 2nd Generation Screen Replacement, Screen: step 1, image 1 of 1
      • Insert plastic opening tool into the corners of the Paperwhite and slide around the edge perimeter to remove bezel.
      • Be sure to begin prying along the edges, these are the optimal points for removing the bezel.
      Ask FixBot
    2. Kindle Paperwhite 2nd Generation Screen Replacement: step 2, image 1 of 2 Kindle Paperwhite 2nd Generation Screen Replacement: step 2, image 2 of 2
      • Remove the eleven 3.2 mm Phillips 000 screws from corners of mid-frame and from behind the black strip as shown.
      • Do not forget the screw in the middle of the black adhesive strip.
      Ask FixBot
    3. Kindle Paperwhite 2nd Generation Screen Replacement: step 3, image 1 of 1
      • Carefully lift and remove the mid-frame.
      Ask FixBot
    4. Kindle Paperwhite 2nd Generation Screen Replacement: step 4, image 1 of 1
      • The screen itself is glued to the mid-frame. If your replacement screen does not include the mid-frame, heat the screen with an iOpener and gently pry it from the mid-frame with a blue plastic opening tool.
      Ask FixBot
8 other people completed this guide.
Author
with
Tyler Davis
2,007 Reputation
5 Guides authored
USF Tampa, Team 11-2, Blackwell Fall 2016 Member of USF Tampa, Team 11-2, Blackwell Fall 2016
USFT-BLACKWELL-F16S11G2
4 Members
60 Guides authored
3 Guide Comments
My opening tool is orange. Will this still work for me?
FoxRunTime - Reply Share
I’m hoping to replace my screen with this part:
Kindle Paperwhite (2nd Gen) Display
Does this part include the mid-frame? I would like to avoid using the iOpener if possible.
Thank you!
Liam Cahill - Reply Share
Did this work Liam?
Ben Lowdon - Reply Share
Past 24 Hours: 6
Past 7 Days: 48
Past 30 Days: 223
All Time: 16,380
