Kindle Paperwhite 2nd Generation Charging Port Replacement
Views: 33K
View statistics:
Past 24 Hours:
11
Past 7 Days:
88
Past 30 Days:
312
All Time:
32,898
Comments: 19
9 comments on steps, 10 guide comments.
Go to guide comments
Completed: 12
12 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 30 - 45 minutes
Difficulty: Moderate
Missing Steps
Oops! This guide is currently missing one or more important steps.
Introduction
Go to step 1 ↓
The Paperwhite’s charging port is integrated into the motherboard, and can only be replaced by either de-soldering the old port and carefully soldering on a new one, or by replacing the entire board.
Parts
Tools
    1. Kindle Paperwhite 2nd Generation Charging Port Replacement, Battery: step 1, image 1 of 2 Kindle Paperwhite 2nd Generation Charging Port Replacement, Battery: step 1, image 2 of 2
      • Insert plastic opening tool into the corners of the Paperwhite and slide around the edge perimeter to remove bezel.
      • Be sure to begin prying along the outer edges , these are the optimal points for removing the bezel.
      • Be careful and do not slide prying tool deeper than 3-4 mm under the side bezel or you could peel off screen protector film.
      Ask FixBot
    2. Kindle Paperwhite 2nd Generation Charging Port Replacement: step 2, image 1 of 2 Kindle Paperwhite 2nd Generation Charging Port Replacement: step 2, image 2 of 2
      • Using a Screw Driver, Remove the eleven 3.2 mm Phillips 000 screws from corners of the mid-frame and from behind the black strip as shown.
      • Do not forget the screw in the middle of the black adhesive strip.
      Ask FixBot
    3. Kindle Paperwhite 2nd Generation Charging Port Replacement: step 3, image 1 of 1
      • Carefully remove the mid-frame from the back cover.
      Ask FixBot
    4. Kindle Paperwhite 2nd Generation Charging Port Replacement: step 4, image 1 of 2 Kindle Paperwhite 2nd Generation Charging Port Replacement: step 4, image 2 of 2
      • Use a screwdriver to remove the three 3.0 mm Phillips 000 screws that are holding the battery in place as shown.
      Ask FixBot
    5. Kindle Paperwhite 2nd Generation Charging Port Replacement: step 5, image 1 of 1
      • Carefully lift the battery and remove it from the device.
      Ask FixBot
    1. Kindle Paperwhite 2nd Generation Charging Port Replacement, Motherboard: step 6, image 1 of 2 Kindle Paperwhite 2nd Generation Charging Port Replacement, Motherboard: step 6, image 2 of 2
      • Use a screwdriver to remove the seven 3.0 mm Phillips 000 screws that are holding the motherboard in place as shown.
      • Don't lose the washer that is highlighted with an orange marker as shown. It is a necessary component to protect the screw.
      Ask FixBot
    2. Kindle Paperwhite 2nd Generation Charging Port Replacement: step 7, image 1 of 2 Kindle Paperwhite 2nd Generation Charging Port Replacement: step 7, image 2 of 2
      • Gently disconnect the zif connectors.
      • Some of these connectors are very thin and fragile, handle with care!
      Ask FixBot
    3. Kindle Paperwhite 2nd Generation Charging Port Replacement: step 8, image 1 of 3 Kindle Paperwhite 2nd Generation Charging Port Replacement: step 8, image 2 of 3 Kindle Paperwhite 2nd Generation Charging Port Replacement: step 8, image 3 of 3
      • Gently remove the motherboard.
      Ask FixBot
    1. Kindle Paperwhite 2nd Generation Charging Port Replacement, Charging Port: step 9, image 1 of 1
      • The charging port is integrated in to the device motherboard.
      • From here, to fix a faulty port, either replace the entire motherboard, or carefully desolder the old port and solder a new one on in its place.
      • Check out the soldering guide for help.
      Ask FixBot
12 other people completed this guide.
Tyler Davis
2,007 Reputation
5 Guides authored
USF Tampa, Team 11-2, Blackwell Fall 2016 Member of USF Tampa, Team 11-2, Blackwell Fall 2016
USFT-BLACKWELL-F16S11G2
4 Members
60 Guides authored
10 Guide Comments
How to replace the USB port; replace the motherboard. Kind of a lame fix if you ask me. Whatever happened to soldering a new port on?
Sam Hardeman - Reply Share
I have not done the fix yet but plan to replace the USB which appears to be a USB - micro B USB 2.0 Receptacle Connector 5 Position Surface Mount available at DigiKey. Is there any reason not to attempt this? I have microscope and soldering station. If not, where do you get the motherboard and how much is it?
Bill Smith - Reply Share
Any updates? Did you run into any issues?
theend12212012 - Reply Share
Démontage facile effectivement, mais les cinq microsoudures sur la carte mère sont impossibles à faire avec un simple fer à souder ! Il faut utiliser du matériel pour CMS (composant à montage en surface)…
Ceci dit mon problème vient effectivement de ces microsoudures. En appuyant simplement sur ces contacts mon Kindle s’est remis en marche ! Vive le travail mal fait à la construction…
telerando - Reply Share
Getting the Kindle open and getting to the charging port was quite ‘easy’. In step 1 the top is stuck on with something like sticky back tape and the top can be gently pulled away from the tape.
Having got to the port I can not figure out how to replace it. This part does not seem to be easy, unless Step 9 is explained in much more detail. The contacts for the port seem to be incredibly small and I can’t figure out how they’re connected, or what part I need to order to replace the port.
Richard Garside - Reply Share
Past 24 Hours: 11
Past 7 Days: 88
Past 30 Days: 312
All Time: 32,898
