Up to 20% off select tools
Kindle Paperwhite 12th Gen Power Button Replacement
View statistics:
Past 24 Hours:
5
Past 7 Days:
34
Past 30 Days:
155
All Time:
988
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 7 - 15 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
The power button on the Kindle Paperwhite 12th Gen is the only button on the device, located to the left of the charging port at the bottom of the device. It is held in with simple rubber placeholders, and can easily be replaced.
This replacement may be necessary if the button is damaged, overly sensitive, or unresponsive, making it difficult to properly use your Kindle.
Before you begin the repair, make sure to power off your Kindle and unplug the charger and any connected accessories.
    1. Kindle Paperwhite 12th Gen Power Button Replacement, Bottom Case: step 1, image 1 of 2 Kindle Paperwhite 12th Gen Power Button Replacement, Bottom Case: step 1, image 2 of 2
      • Use an opening tool or opening picks and insert the tip between the back case and screen.
      • Slide the opening tool around the edge of the tablet to release the clips holding them together and avoid damaging the connectors.
      • You can also place additional opening picks in the space between the top and bottom case to prevent the front and back cases from snapping back together.
      Ask FixBot
    2. Kindle Paperwhite 12th Gen Power Button Replacement: step 2, image 1 of 2 Kindle Paperwhite 12th Gen Power Button Replacement: step 2, image 2 of 2
      • Flip the Kindle over and remove back casing from screen and device.
      • When reassembling, align the top and bottom case and press until they click into place.
      Ask FixBot
    1. Kindle Paperwhite 12th Gen Power Button Replacement, Power button: step 3, image 1 of 3 Kindle Paperwhite 12th Gen Power Button Replacement, Power button: step 3, image 2 of 3 Kindle Paperwhite 12th Gen Power Button Replacement, Power button: step 3, image 3 of 3
      • Use tweezers or your fingers to release the clips on each side of the button, gently lifting one side at a time.
      • The button housing is located at the bottom left of the charging port.
      Ask FixBot
Author
with
CatPajamaParty
185 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 34
Past 30 Days: 155
All Time: 988
