Up to 20% off select tools
Kindle Paperwhite 12th Gen Bottom Case Replacement
Views: 1.3K
View statistics:
Past 24 Hours:
5
Past 7 Days:
36
Past 30 Days:
158
All Time:
1,278
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 - 15 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
The back casing of the Kindle serves as a protective shell for its internal components. Removing it is the first step in accessing the device for any repairs or maintenance.
This repair may be necessary if the back casing is cracked, scratched, or otherwise damaged for cosmetic reasons. Additionally, if the clips securing the casing are broken or worn out, the cover may not stay in place properly and will need replacement. Be mindful that improper removal can further damage these clips or other internal parts. Follow this guide carefully to avoid any unintended damage to your Kindle Paperwhite 12th Gen.
Before proceeding, ensure the device is powered off and any external accessories are disconnected.
    1. Kindle Paperwhite 12th Gen Bottom Case Replacement, Bottom Case: step 1, image 1 of 2 Kindle Paperwhite 12th Gen Bottom Case Replacement, Bottom Case: step 1, image 2 of 2
      • Use an opening tool or opening picks and insert the tip between the back case and screen.
      • Slide the opening tool around the edge of the tablet to release the clips holding them together and avoid damaging the connectors.
      • You can also place additional opening picks in the space between the top and bottom case to prevent the front and back cases from snapping back together.
      Ask FixBot
    2. Kindle Paperwhite 12th Gen Bottom Case Replacement: step 2, image 1 of 2 Kindle Paperwhite 12th Gen Bottom Case Replacement: step 2, image 2 of 2
      • Flip the Kindle over and remove back casing from screen and device.
      • When reassembling, align the top and bottom case and press until they click into place.
      Ask FixBot
Author
with
Wyatt
302 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 36
Past 30 Days: 158
All Time: 1,278
