Up to 20% off select tools
Kindle Fire Power Button Board Replacement
Views: 36K
View statistics:
Past 24 Hours:
4
Past 7 Days:
27
Past 30 Days:
145
All Time:
35,541
Comments: 20
19 comments on steps, 1 guide comment.
Go to guide comments
Completed: 18
18 people have marked this guide "completed." Will you be next?
Favorites: 14
14 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 20 - 30 minutes
Difficulty: Moderate
Parts
Tools
Introduction
Go to step 1 ↓
Use this guide to help you replace a faulty power button board in your Amazon Kindle Fire.
    1. Kindle Fire Power Button Board Replacement, Back Case: step 1, image 1 of 3 Kindle Fire Power Button Board Replacement, Back Case: step 1, image 2 of 3 Kindle Fire Power Button Board Replacement, Back Case: step 1, image 3 of 3
      • Wedge a plastic opening tool into the lower right corner of the Kindle Fire.
      • Pry the case apart and run the plastic opening tool along the perimeter of the Kindle Fire to release the clips securing the case halves to each other.
      • If you are having extreme difficulty inserting the plastic opening tool, carefully use a metal spudger to undo the first clip, then switch back to the opening tool to avoid scratching your case.
      • It is helpful to pry the bottom of the Kindle Fire away (and out from the side) from the top part. Exerting too much force attempting to split the two without pulling away can cause the tabs on the inside to crack.
      Ask FixBot
    2. Kindle Fire Power Button Board Replacement: step 2, image 1 of 1
      • Once you have freed all the plastic clips, pull the back case off the Kindle Fire.
      Ask FixBot
    1. Kindle Fire Power Button Board Replacement, Battery: step 3, image 1 of 3 Kindle Fire Power Button Board Replacement, Battery: step 3, image 2 of 3 Kindle Fire Power Button Board Replacement, Battery: step 3, image 3 of 3
      • Fit the tip of the plastic opening tool between the right battery cell and the Kindle Fire's frame.
      • Lever the battery up and work the plastic opening tool down along its edge to release the glue securing it to the frame.
      Ask FixBot
    2. Kindle Fire Power Button Board Replacement: step 4, image 1 of 1
      • Repeat the process from the previous step to free the left battery cell.
      Ask FixBot
    3. Kindle Fire Power Button Board Replacement: step 5, image 1 of 2 Kindle Fire Power Button Board Replacement: step 5, image 2 of 2
      • Lift the back of the battery up to relieve any tension in the battery connector and simultaneously use a spudger to push the battery connector out of its socket.
      • Pull the battery out of the Kindle Fire.
      Ask FixBot
    1. Kindle Fire Power Button Board Replacement, Motherboard: step 6, image 1 of 3 Kindle Fire Power Button Board Replacement, Motherboard: step 6, image 2 of 3 Kindle Fire Power Button Board Replacement, Motherboard: step 6, image 3 of 3
      • Remove the two 2.3 mm Phillips #00 screws from the touchscreen controller.
      • Use a plastic opening tool to release the touchscreen controller connector.
      • Gently remove the touchscreen controller by lifting it up and to the right.
      • Be careful not to rip the ribbon cable in doing so.
      Ask FixBot
    2. Kindle Fire Power Button Board Replacement: step 7, image 1 of 3 Kindle Fire Power Button Board Replacement: step 7, image 2 of 3 Kindle Fire Power Button Board Replacement: step 7, image 3 of 3
      Tool used on this step:
      Buy
      • Use a plastic opening tool to flip open the power button ZIF connector.
      • This connector will not be removed until the motherboard is free.
      • Flip open the ambient light sensor ZIF socket with a plastic opening tool.
      • Use a pair of tweezers to pull the blue tab on the ambient light sensor cable to remove it from its socket.
      Ask FixBot
    3. Kindle Fire Power Button Board Replacement: step 8, image 1 of 3 Kindle Fire Power Button Board Replacement: step 8, image 2 of 3 Kindle Fire Power Button Board Replacement: step 8, image 3 of 3
      • Use a plastic opening tool to lift up and disconnect the display data cable.
      • Lift up on the antenna connector with a plastic opening tool to disconnect it.
      • De-route the antenna cable.
      Ask FixBot
    4. Kindle Fire Power Button Board Replacement: step 9, image 1 of 1
      • Remove the six 2.6 mm Phillips #00 screws securing the motherboard to the frame.
      Ask FixBot
    5. Kindle Fire Power Button Board Replacement: step 10, image 1 of 3 Kindle Fire Power Button Board Replacement: step 10, image 2 of 3 Kindle Fire Power Button Board Replacement: step 10, image 3 of 3
      • Use a plastic opening tool to gently lever up the bottom side of the motherboard to free from the adhesive on its underside.
      • Lever the top side of the motherboard up with a plastic opening tool until it comes free.
      • Lift the motherboard out of the Kindle Fire, making sure that the power button cable from step 8 comes free from its connector.
      Ask FixBot
    1. Kindle Fire Power Button Board Replacement, Power Button Board: step 11, image 1 of 2 Kindle Fire Power Button Board Replacement, Power Button Board: step 11, image 2 of 2
      • Remove the 2.5 mm Phillips #00 scew securing the power button board to the Kindle Fire.
      • Lift the power button board out of the Kindle Fire.
      Ask FixBot
18 other people completed this guide.
Author
with
Phillip Takahashi
88,177 Reputation
87 Guides authored
1 Guide Comment
This PCB does not contain the power button, only the power LED. The button is located on the main PCB next to the USB port.
jcross1986 - Reply Share
Past 24 Hours: 4
Past 7 Days: 27
Past 30 Days: 145
All Time: 35,541
