Kindle Fire HDX 7" Rear Panel Replacement
    1. Kindle Fire HDX 7" Rear Panel Replacement, Speaker Bezel: step 1, image 1 of 3 Kindle Fire HDX 7" Rear Panel Replacement, Speaker Bezel: step 1, image 2 of 3 Kindle Fire HDX 7" Rear Panel Replacement, Speaker Bezel: step 1, image 3 of 3
      • Insert an opening pick underneath the speaker bezel, and slide it along the perimeter to separate it from the tablet.
      • The adhesive is strong and may require an iOpener, or heat gun, to soften.
      Ask FixBot
    2. Kindle Fire HDX 7" Rear Panel Replacement: step 2, image 1 of 1
      • Remove the speaker bezel.
      Ask FixBot
    1. Kindle Fire HDX 7" Rear Panel Replacement, Rear Panel: step 3, image 1 of 1
      • Remove the six pink 3mm T3 Torx screws from the back case.
      Ask FixBot
    2. Kindle Fire HDX 7" Rear Panel Replacement: step 4, image 1 of 2 Kindle Fire HDX 7" Rear Panel Replacement: step 4, image 2 of 2
      • Wedge opening picks around the perimeter between the display and back case.
      • Work the opening picks around the perimeter until the two halves disengage from each other.
      • Don't completely separate as the display ribbon cable still connects the two.
      Ask FixBot
    3. Kindle Fire HDX 7" Rear Panel Replacement: step 5, image 1 of 1
      • Use the flat end of a spudger to pry up and disconnect the rear panel press-fit connector from the motherboard.
      Ask FixBot
      • There may be a glue strip between the battery and the outside case. Gently pry the case open and use the flat end of a spudger to separate the glue strip.
      Ask FixBot
Blake Klein
75,435 Reputation
50 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 30
Past 30 Days: 73
All Time: 1,177
