Kindle Fire HDX 7" Motherboard Replacement
    1. Kindle Fire HDX 7" Motherboard Replacement, Speaker Bezel: step 1, image 1 of 3 Kindle Fire HDX 7" Motherboard Replacement, Speaker Bezel: step 1, image 2 of 3 Kindle Fire HDX 7" Motherboard Replacement, Speaker Bezel: step 1, image 3 of 3
      • Insert an opening pick underneath the speaker bezel, and slide it along the perimeter to separate it from the tablet.
      • The adhesive is strong and may require an iOpener, or heat gun, to soften.
      Ask FixBot
    2. Kindle Fire HDX 7" Motherboard Replacement: step 2, image 1 of 1
      • Remove the speaker bezel.
      Ask FixBot
    1. Kindle Fire HDX 7" Motherboard Replacement, Rear Panel: step 3, image 1 of 1
      • Remove the six pink 3mm T3 Torx screws from the back case.
      Ask FixBot
    2. Kindle Fire HDX 7" Motherboard Replacement: step 4, image 1 of 2 Kindle Fire HDX 7" Motherboard Replacement: step 4, image 2 of 2
      • Wedge opening picks around the perimeter between the display and back case.
      • Work the opening picks around the perimeter until the two halves disengage from each other.
      • Don't completely separate as the display ribbon cable still connects the two.
      Ask FixBot
    3. Kindle Fire HDX 7" Motherboard Replacement: step 5, image 1 of 1
      • Use the flat end of a spudger to pry up and disconnect the rear panel press-fit connector from the motherboard.
      Ask FixBot
      • There may be a glue strip between the battery and the outside case. Gently pry the case open and use the flat end of a spudger to separate the glue strip.
      Ask FixBot
    1. Kindle Fire HDX 7" Motherboard Replacement, Motherboard: step 7, image 1 of 2 Kindle Fire HDX 7" Motherboard Replacement, Motherboard: step 7, image 2 of 2
      Tool used on this step:
      Buy
      • Grab the yellow tape with a pair of tweezers and pull upwards to disconnect the press-fit connector.
      Ask FixBot
    2. Kindle Fire HDX 7" Motherboard Replacement: step 8, image 1 of 1
      • Use the flat end of a spudger to disconnect the front camera press-fit connector from the motherboard.
      Ask FixBot
    3. Kindle Fire HDX 7" Motherboard Replacement: step 9, image 1 of 1
      • Remove the nine 3mm T6 Torx screws from the motherboard.
      Ask FixBot
    4. Kindle Fire HDX 7" Motherboard Replacement: step 10, image 1 of 3 Kindle Fire HDX 7" Motherboard Replacement: step 10, image 2 of 3 Kindle Fire HDX 7" Motherboard Replacement: step 10, image 3 of 3
      • Use a spudger to pry up and disconnect the antenna cable from the motherboard.
      • Pull the antenna cable up and off of the motherboard.
      • Don't remove completely as it's soldered to the frame.
      Ask FixBot
    5. Kindle Fire HDX 7" Motherboard Replacement: step 11, image 1 of 1
      • Use a spudger to disconnect the second antenna cable from the motherboard.
      Ask FixBot
    6. Kindle Fire HDX 7" Motherboard Replacement: step 12, image 1 of 2 Kindle Fire HDX 7" Motherboard Replacement: step 12, image 2 of 2
      • Use the flat end of a spudger to pry up and disconnect the front camera press-fit connector from the motherboard.
      • Remove the front camera.
      Ask FixBot
    7. Kindle Fire HDX 7" Motherboard Replacement: step 13, image 1 of 2 Kindle Fire HDX 7" Motherboard Replacement: step 13, image 2 of 2
      • Remove the motherboard from the tablet.
      Ask FixBot
Blake Klein
75,435 Reputation
50 Guides authored
2 Guide Comments
This is a good tutorial but there is no mention of the bottom two connectors attached to the motherboard and some tips on reattaching these, i.e. the connector cables can be extended and then pulled back to normal to make reattachment possible
Harry Hofmeister - Reply Share
Exactly! Followed this tutorial today, wanted to replace motherboard, and almost ripped off the lcd/touch connectors and flat cables because didn’t know they are there. It’s a bit difficult to put them back, be careful.
Neb Sek - Reply Share
Past 24 Hours: 3
Past 7 Days: 30
Past 30 Days: 91
All Time: 2,052
