Kindle Fire HDX 7" Micro USB Charging Port Replacement
Views: 7.7K
View statistics:
Past 24 Hours:
0
Past 7 Days:
13
Past 30 Days:
94
All Time:
7,709
Comments: 2
2 comments on steps.
Completed: 6
6 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 30 minutes - 1 hour
Difficulty: Moderate
Introduction
Go to step 1 ↓
Replacement guide for the micro USB charging port on a Kindle Fire HDX 7” tablet.
The home button and micro USB are part of the same ribbon cable and are replaced at the same time.
Parts
Tools
    1. Kindle Fire HDX 7" Micro USB Charging Port Replacement, Speaker Bezel: step 1, image 1 of 3 Kindle Fire HDX 7" Micro USB Charging Port Replacement, Speaker Bezel: step 1, image 2 of 3 Kindle Fire HDX 7" Micro USB Charging Port Replacement, Speaker Bezel: step 1, image 3 of 3
      • Insert an opening pick underneath the speaker bezel, and slide it along the perimeter to separate it from the tablet.
      • The adhesive is strong and may require an iOpener, or heat gun, to soften.
      Ask FixBot
    2. Kindle Fire HDX 7" Micro USB Charging Port Replacement: step 2, image 1 of 1
      • Remove the speaker bezel.
      Ask FixBot
    1. Kindle Fire HDX 7" Micro USB Charging Port Replacement, Rear Panel: step 3, image 1 of 1
      • Remove the six pink 3mm T3 Torx screws from the back case.
      Ask FixBot
    2. Kindle Fire HDX 7" Micro USB Charging Port Replacement: step 4, image 1 of 2 Kindle Fire HDX 7" Micro USB Charging Port Replacement: step 4, image 2 of 2
      • Wedge opening picks around the perimeter between the display and back case.
      • Work the opening picks around the perimeter until the two halves disengage from each other.
      • Don't completely separate as the display ribbon cable still connects the two.
      Ask FixBot
    3. Kindle Fire HDX 7" Micro USB Charging Port Replacement: step 5, image 1 of 1
      • Use the flat end of a spudger to pry up and disconnect the rear panel press-fit connector from the motherboard.
      Ask FixBot
      • There may be a glue strip between the battery and the outside case. Gently pry the case open and use the flat end of a spudger to separate the glue strip.
      Ask FixBot
    1. Kindle Fire HDX 7" Micro USB Charging Port Replacement, Micro USB Charging Port: step 7, image 1 of 1
      • Remove the four 2.3mm T5 Torx screws from the micro USB port and power button assembly.
      Ask FixBot
    2. Kindle Fire HDX 7" Micro USB Charging Port Replacement: step 8, image 1 of 2 Kindle Fire HDX 7" Micro USB Charging Port Replacement: step 8, image 2 of 2
      • Pry up the ribbon cable from the rear panel with the flat end of a spudger.
      • Remove the micro USB port and power button ribbon cable.
      Ask FixBot
6 other people completed this guide.
Blake Klein
75,439 Reputation
50 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 13
Past 30 Days: 94
All Time: 7,709
