Kindle Fire HDX 7" Headphone Jack Replacement
    1. Kindle Fire HDX 7" Headphone Jack Replacement, Speaker Bezel: step 1, image 1 of 3 Kindle Fire HDX 7" Headphone Jack Replacement, Speaker Bezel: step 1, image 2 of 3 Kindle Fire HDX 7" Headphone Jack Replacement, Speaker Bezel: step 1, image 3 of 3
      • Insert an opening pick underneath the speaker bezel, and slide it along the perimeter to separate it from the tablet.
      • The adhesive is strong and may require an iOpener, or heat gun, to soften.
      Ask FixBot
    2. Kindle Fire HDX 7" Headphone Jack Replacement: step 2, image 1 of 1
      • Remove the speaker bezel.
      Ask FixBot
    1. Kindle Fire HDX 7" Headphone Jack Replacement, Rear Panel: step 3, image 1 of 1
      • Remove the six pink 3mm T3 Torx screws from the back case.
      Ask FixBot
    2. Kindle Fire HDX 7" Headphone Jack Replacement: step 4, image 1 of 2 Kindle Fire HDX 7" Headphone Jack Replacement: step 4, image 2 of 2
      • Wedge opening picks around the perimeter between the display and back case.
      • Work the opening picks around the perimeter until the two halves disengage from each other.
      • Don't completely separate as the display ribbon cable still connects the two.
      Ask FixBot
    3. Kindle Fire HDX 7" Headphone Jack Replacement: step 5, image 1 of 1
      • Use the flat end of a spudger to pry up and disconnect the rear panel press-fit connector from the motherboard.
      Ask FixBot
      • There may be a glue strip between the battery and the outside case. Gently pry the case open and use the flat end of a spudger to separate the glue strip.
      Ask FixBot
    1. Kindle Fire HDX 7" Headphone Jack Replacement, Headphone Jack: step 7, image 1 of 1
      • Remove the single 3.1mm T5 Torx screw from the headphone jack.
      Ask FixBot
    2. Kindle Fire HDX 7" Headphone Jack Replacement: step 8, image 1 of 1
      Tool used on this step:
      Buy
      • Pull the headphone jack out of its socket with a pair of tweezers to remove.
      Ask FixBot
Blake Klein
75,154 Reputation
50 Guides authored
2 Guide Comments
Thanks guys. My kindle had the stub of a mini plug broken off in it. Had it so that I could plug devices into my stereo and after many plug-ins of different devices some how the tip was cracked, should have realized it, the plug had gotten intermittent but I kept using it(25 foot cord mini-plug to RCA plugs). I use this instruction guide get socket assembly out, but still had to carve the socket body on the side a bit to get a my smallest pair of needle nose in to grasp and pull plug tip out. It was not easy, but couldn’t have gotten to that point without this guide. Reassembled and all works well, thanks again.
Steve
I really wanted to fix this Kindle, had received it as a drawing prize from alumni association when I graduated from Purdue Fort Wayne a few years ago.
Love your site!
Steve - Reply Share
Um by the way, in case anybody accidentally separates the cable(the tape will hold in place, but the SMD multi-pin male to female connector can become dislodged easily(for me anyway). Don’t panic, the plug will firmly snap back into place, if you line it up fairly close and apply slight downward pressure. you’ll have to have very good vision or some optics to see the socket/header clearly.
Didn’t realize on my first post that Blake had written this, thanks a lot Blake!
Steve
Steve - Reply Share
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 39
All Time: 1,761
