Kindle Fire HD 8.9" Charger & Micro HDMI Input Replacement
    1. Kindle Fire HD 8.9" Charger & Micro HDMI Input Replacement, Screen: step 1, image 1 of 3 Kindle Fire HD 8.9" Charger & Micro HDMI Input Replacement, Screen: step 1, image 2 of 3 Kindle Fire HD 8.9" Charger & Micro HDMI Input Replacement, Screen: step 1, image 3 of 3
      • Insert a large plastic opening tool next to the Kindle's headphone jack.
      • Make sure the notch on the plastic opening tool is facing the back of the Kindle.
      • Move the plastic opening tool evenly around the Kindle, separating the two halves.
      • Be careful not to completely separate the rear cover. There are two delicate flex cables that connect the display assembly to the motherboard.
      Ask FixBot
    2. Kindle Fire HD 8.9" Charger & Micro HDMI Input Replacement: step 2, image 1 of 1
      • Set the Kindle down on the rear case.
      • Holding the display assembly near the camera, carefully open the display assembly up to about 90 degrees from the rear case.
      • These images show the Kindle laying flat. In order to prevent damage to the flex cables, keep the Kindle open at 90 degrees while disconnecting the display assembly.
      Ask FixBot
    3. Kindle Fire HD 8.9" Charger & Micro HDMI Input Replacement: step 3, image 1 of 3 Kindle Fire HD 8.9" Charger & Micro HDMI Input Replacement: step 3, image 2 of 3 Kindle Fire HD 8.9" Charger & Micro HDMI Input Replacement: step 3, image 3 of 3
      • Lift the retaining flap on the ZIF connector of the upper flex cable.
      • Gently pull the cable out of its socket.
      • This flex cable is delicate. Be careful not to crease or bend it while working.
      Ask FixBot
    4. Kindle Fire HD 8.9" Charger & Micro HDMI Input Replacement: step 4, image 1 of 1
      • Separate the display assembly from the rest of the device.
      • When reassembling the device, align the two halves of the case before connecting the flex cables.
      Ask FixBot
    1. Kindle Fire HD 8.9" Charger & Micro HDMI Input Replacement, Inner Metal Casing: step 5, image 1 of 2 Kindle Fire HD 8.9" Charger & Micro HDMI Input Replacement, Inner Metal Casing: step 5, image 2 of 2
      • Remove the following sixteen screws from the metal midframe on the rear of the device:
      • Four 3 mm Phillips screw (located in each corner of the device - noted in red in the diagram)
      • Four 3 mm Phillips screws (surrounding the ports - noted in orange in the diagram)
      • Eight 3 mm Phillips screws (located around the body of the midframe - noted in yellow in the diagram)
      Ask FixBot
    2. Kindle Fire HD 8.9" Charger & Micro HDMI Input Replacement: step 6, image 1 of 2 Kindle Fire HD 8.9" Charger & Micro HDMI Input Replacement: step 6, image 2 of 2
      • Carefully remove the metal midframe.
      Ask FixBot
    1. Kindle Fire HD 8.9" Charger & Micro HDMI Input Replacement, Charger & Micro HDMI Input: step 7, image 1 of 3 Kindle Fire HD 8.9" Charger & Micro HDMI Input Replacement, Charger & Micro HDMI Input: step 7, image 2 of 3 Kindle Fire HD 8.9" Charger & Micro HDMI Input Replacement, Charger & Micro HDMI Input: step 7, image 3 of 3
      • Locate the charger and micro HDMI input located on the back side of your Kindle.
      • Use your finger to gently apply pressure and push upward on the metal strip that faces the center of the Kindle.
      • Be careful to not bend the black portion that connects the two inputs when removing the metal strip.
      • Lift the metal strip on both sides by using your fingers.
      Ask FixBot
    2. Kindle Fire HD 8.9" Charger & Micro HDMI Input Replacement: step 8, image 1 of 1
      • You have now successfully removed the charger and micro HDMI input.
      Ask FixBot
18 other people completed this guide.
Joel Wilcox
524 Reputation
1 Guide authored
Cal Poly, Team 5-16, Forte Winter 2013 Member of Cal Poly, Team 5-16, Forte Winter 2013
CPSU-FORTE-W13S5G16
5 Members
84 Guides authored
9 Guide Comments
Where can I purchase the Charger and Micro HDMI input replacement part for my Kindle Fire HD 8.9 tablet?
greggbaxter - Reply Share
If you search Google for "Amazon Kindle Fire HD 8.9" Dock Assembly" a few will show up.
Shawn Allen - Reply Share
ebay is going to have the most options for any phone tablet etc parts. Look for your model number (general tip) do not just look for as a example samsung s3 mini glass there are variants based on carrier. So make sure your buying a kindle fire 8.9 and not a hdx part. I think in the 8.9 hds there are 2 variants i know there are 2 storage configs. So make sure you get the right part.
First link on ebay search kindle fire hd 8.9 hdmi port (has both ports) http://www.ebay.com/itm/Kindle-fire-HD-8... 25 bucks (note i have not used this seller previously and do not in any way support him/her or say to not buy from him/her This is only a example link showing average cost) This likely is not the best deal it is 28 ship with the 3 shipping tacked on.
Nova Flare - Reply Share
I'm all finished, I had a real problem figuring out the lock key. Now that I am all finished though the touchscreen is unresponsive. What the heck could I have done? I found this quite simple. And what the heck can I do to fix it? Any help would be awesome. Thanks!
Aimee Gordon - Reply Share
Same issue here...
mikebrownson - Reply Share
Past 24 Hours: 4
Past 7 Days: 22
Past 30 Days: 102
All Time: 27,530
