Up to 20% off select tools
Kindle Fire HD 6 Back Panel Replacement
Views: 2.8K
View statistics:
Past 24 Hours:
3
Past 7 Days:
22
Past 30 Days:
120
All Time:
2,839
Comments: 2
2 comments on steps.
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 2 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
Removing the back panel of the Kindle Fire HD 6 is very important, because you can't access any of the other components until you remove the back panel. In this guide, we'll cover how to remove this panel so that you can replace the components inside.
    1. Kindle Fire HD 6 Back Panel Replacement, Back Panel: step 1, image 1 of 1
      • Place the device face down on a clean cloth or another smooth surface.
      • In the following steps, you will need to apply some force to your device. If your device is on a rough surface, you may scratch the screen.
      • Insert the plastic opening tool between the device’s front and back panels. You might need to wiggle the tool up and down to wedge it in the gap.
      • Maneuver the tool around the device until the back unclips from the front panel.
      Ask FixBot
    2. Kindle Fire HD 6 Back Panel Replacement: step 2, image 1 of 2 Kindle Fire HD 6 Back Panel Replacement: step 2, image 2 of 2
      • Carefully separate the back panel from the rest of the device internals.
      Ask FixBot
2 other people completed this guide.
Author
with
000
988 Reputation
1 Guide authored
Cal Poly, Team 70-4, Forte Winter 2015 Member of Cal Poly, Team 70-4, Forte Winter 2015
CPSU-FORTE-W15S70G4
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 22
Past 30 Days: 120
All Time: 2,839
