Up to 20% off select tools
Kindle Fire HD 10 Camera Replacement
Views: 2.9K
View statistics:
Past 24 Hours:
2
Past 7 Days:
10
Past 30 Days:
73
All Time:
2,890
Comments: 6
5 comments on steps, 1 guide comment.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
If your Kindle Fire HD 10 7th Generation camera is malfunctioning or damaged, use this guide to replace the camera. This guide gives instructions on how to access the rear camera. The camera allows you to take pictures or videos. While using your camera, if there are error messages, a black screen, or see physical damage to the lens, you may be unable to capture photos or videos. Use caution when removing tablet components. Before beginning, make sure to power off your device completely and disconnect from any external power source.
    1. Kindle Fire HD 10 Camera Replacement, Camera: step 1, image 1 of 3 Kindle Fire HD 10 Camera Replacement, Camera: step 1, image 2 of 3 Kindle Fire HD 10 Camera Replacement, Camera: step 1, image 3 of 3
      • Pry open the case using the iFixit opening tool.
      • Make sure to go around the whole case before removing the whole case.
      Ask FixBot
    2. Kindle Fire HD 10 Camera Replacement: step 2, image 1 of 2 Kindle Fire HD 10 Camera Replacement: step 2, image 2 of 2
      • Remove yellow tape covering the connecter.
      Ask FixBot
    3. Kindle Fire HD 10 Camera Replacement: step 3, image 1 of 3 Kindle Fire HD 10 Camera Replacement: step 3, image 2 of 3 Kindle Fire HD 10 Camera Replacement: step 3, image 3 of 3
      • Gently flip over the black latch with the iFixit opening tool. Disconnect the camera's connector to the circuit board.
      Ask FixBot
    4. Kindle Fire HD 10 Camera Replacement: step 4, image 1 of 3 Kindle Fire HD 10 Camera Replacement: step 4, image 2 of 3 Kindle Fire HD 10 Camera Replacement: step 4, image 3 of 3
      Tool used on this step:
      Buy
      • Remove the rubber casing around the camera lens using a set of tweezers.
      Ask FixBot
    5. Kindle Fire HD 10 Camera Replacement: step 5, image 1 of 1
      • Remove and pull off the camera lens.
      Ask FixBot
Author
with
William Hess
797 Reputation
3 Guides authored
1 Guide Comment
Where can I buy the lens?
Victoria Feldman - Reply Share
Past 24 Hours: 2
Past 7 Days: 10
Past 30 Days: 73
All Time: 2,890
