Introduction
Go to step 1 ↓Use this guide to help you replace a broken front glass panel or digitizer in an Amazon Kindle Fire.
Wedge a plastic opening tool into the lower right corner of the Kindle Fire.
Pry the case apart and run the plastic opening tool along the perimeter of the Kindle Fire to release the clips securing the case halves to each other.
It is helpful to pry the bottom of the Kindle Fire away (and out from the side) from the top part. Exerting too much force attempting to split the two without pulling away can cause the tabs on the inside to crack.
Fit the tip of the plastic opening tool between the right battery cell and the Kindle Fire's frame.
Lever the battery up and work the plastic opening tool down along its edge to release the glue securing it to the frame.
Peel the tape on the upper-left IC that is securing the speaker cable.
Use the flat end of a spudger to push the speaker connector out of its socket.
Deroute the speaker cable.
Remove the two 2.3 mm Phillips #00 screws from the touchscreen controller.
Use a plastic opening tool to release the touchscreen controller connector.
Gently remove the touchscreen controller by lifting it up and to the right.
Tool used on this step:Tweezers$4.99
Use a plastic opening tool to flip open the power button ZIF connector.
Flip open the ambient light sensor ZIF socket with a plastic opening tool.
Use a pair of tweezers to pull the blue tab on the ambient light sensor cable to remove it from its socket.
Use a plastic opening tool to gently lever up the bottom side of the motherboard to free from the adhesive on its underside.
Lever the top side of the motherboard up with a plastic opening tool until it comes free.
Lift the motherboard out of the Kindle Fire, making sure that the power button cable from step 8 comes free from its connector.
Remove the 2.5 mm Phillips #00 scew securing the power button board to the Kindle Fire.
Lift the power button board out of the Kindle Fire.
Use the flat end of a spudger to peel the ambient light sensor cable off of the frame.
Slide the ambient light sensor out from under the frame and remove it from the Kindle Fire.
Use the flat end of a spudger to lever the frame away from the display assembly until you can grab it with your hand.
Remove the frame from the display assembly.
Remove the four 2.4 mm Phillips #00 screws attaching the LCD to the front glass panel.
Rotate the top of the LCD 90 degrees away from the front glass panel as shown in the second picture.
Separate the LCD and front glass panel.
85 other people completed this guide.
25 Guide Comments
This took me about an hour from start to finish - taking my time to mark all the screws etc. but it may take longer if you don't have the correct tools. I agree that there should be a photo of separating the front glass digitizer from the front bezel as the true last step - it can be tricky, and the replacements I have seen don't include the front bezel. I used a razor/hobby knife to slowly peel and separate the digitizer working slowly and carefully from the inside bottom (around and behind the power button cutout) - some goo-gone or lighter fluid will be necessary to clean any old adhesive residue from the bezel as well. The front bezel has a rubberized gasket that should not be remover, so take care to see that you are not peeling that off. My last suggestion is to wear latex or nitrile gloves to prevent getting smudges on the LCD or digitizer during replacement; put them on for step 18, and until you have the frame back in place - care to keep dust out from in between during reassembly is a must!
How do I know which part I need?? Do I need the lcd screen and/or the digitizer?? What's the difference?? My kindle was dropped unfortunately and I am trying to find the part to replace it with. PLEASE HELP!! People are trying to charge me 100$ to replace the screen alone, excluding labor.
