Up to 20% off select tools
Kindle 7th Generation Front Panel Replacement
Views: 7.1K
View statistics:
Past 24 Hours:
6
Past 7 Days:
37
Past 30 Days:
157
All Time:
7,129
Comments: 5
5 comments on steps.
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 minutes
Difficulty: Easy
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
    1. Kindle 7th Generation Front Panel Replacement, Front Panel: step 1, image 1 of 2 Kindle 7th Generation Front Panel Replacement, Front Panel: step 1, image 2 of 2
      • Power off your Kindle before beginning disassembly.
      • At each corner, use the blue plastic opening tool to unhook and separate the front panel from the adhesive.
      • Run the tool along the seams to pry open the front panel.
      Ask FixBot
    2. Kindle 7th Generation Front Panel Replacement: step 2, image 1 of 1
      • Peel the front panel off to remove it from the Kindle.
      • If this is the first time the front panel has been removed, the adhesive may require a significant amount of force to undo.
      • To prevent damaging the front panel, peel the panel from the corners towards the middle of the Kindle.
      • When reassembling your device, if you are replacing the front panel, additional adhesive may be required.
      Ask FixBot
4 other people completed this guide.
Author
with
Abby Roulier
1,241 Reputation
3 Guides authored
Cal Poly, Team 6-28, Amido Winter 2015 Member of Cal Poly, Team 6-28, Amido Winter 2015
CPSU-AMIDO-W15S6G28
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 37
Past 30 Days: 157
All Time: 7,129
