Up to 20% off select tools
Kindle 7th Generation Battery Replacement
Views: 71K
View statistics:
Past 24 Hours:
49
Past 7 Days:
338
Past 30 Days:
1,440
All Time:
71,209
Comments: 38
10 comments on steps, 28 guide comments.
Go to guide comments
Completed: 39
39 people have marked this guide "completed." Will you be next?
Favorites: 10
10 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 - 20 minutes
Difficulty: Moderate
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Parts
Tools
Introduction
Go to step 1 ↓
Having battery issues that require replacement? Well you're in the right place. You're also in luck: the battery is the easiest internal component of the Kindle 7th generation to replace. Follow this guide and your Kindle should be working in no time.
Note: this guide is a for a standard Kindle 7th Gen. This is NOT the same as Kindle Paperwhite 7th Gen, or Kindle Voyage 2014!
    1. Kindle 7th Generation Battery Replacement, Front Panel: step 1, image 1 of 2 Kindle 7th Generation Battery Replacement, Front Panel: step 1, image 2 of 2
      • Power off your Kindle before beginning disassembly.
      • At each corner, use the blue plastic opening tool to unhook and separate the front panel from the adhesive.
      • Run the tool along the seams to pry open the front panel.
      Ask FixBot
    2. Kindle 7th Generation Battery Replacement: step 2, image 1 of 1
      • Peel the front panel off to remove it from the Kindle.
      • If this is the first time the front panel has been removed, the adhesive may require a significant amount of force to undo.
      • To prevent damaging the front panel, peel the panel from the corners towards the middle of the Kindle.
      • When reassembling your device, if you are replacing the front panel, additional adhesive may be required.
      Ask FixBot
    1. Kindle 7th Generation Battery Replacement, Back Panel: step 3, image 1 of 2 Kindle 7th Generation Battery Replacement, Back Panel: step 3, image 2 of 2
      • Remove the ten 5.0 mm T5 Torx screws.
      • A magnetized screw mat can help you keep track of your screws.
      Ask FixBot
    2. Kindle 7th Generation Battery Replacement: step 4, image 1 of 1
      • Working evenly along the corners and edges, separate the internal contents from the back panel.
      • There are many clips securing the screen to the back panel. Force will be required to remove the back, but you should never feel that the Kindle may break.
      Ask FixBot
    1. Kindle 7th Generation Battery Replacement, Battery: step 5, image 1 of 1
      • Flip the Kindle over, exposing the battery and motherboard.
      Ask FixBot
    2. Kindle 7th Generation Battery Replacement: step 6, image 1 of 2 Kindle 7th Generation Battery Replacement: step 6, image 2 of 2
      Tool used on this step:
      Buy
      • Use the blunted precision tweezers to pinch the ends of the clip securing the battery cord to the motherboard.
      • Gently slide the cord from the motherboard connection.
      Ask FixBot
    3. Kindle 7th Generation Battery Replacement: step 7, image 1 of 3 Kindle 7th Generation Battery Replacement: step 7, image 2 of 3 Kindle 7th Generation Battery Replacement: step 7, image 3 of 3
      • Use the plastic opening tool to pry the battery from the backside of the screen.
      • Set the battery aside.
      • The battery has excessive adhesive so this may take some extra effort. See picture of battery deformed by prying tool during removal.
      • If replacing your battery, safely dispose of your damaged battery and use adhesive to insert the new battery.
      Ask FixBot
39 other people completed this guide.
Author
with
Abby Roulier
1,241 Reputation
3 Guides authored
Cal Poly, Team 6-28, Amido Winter 2015 Member of Cal Poly, Team 6-28, Amido Winter 2015
CPSU-AMIDO-W15S6G28
4 Members
72 Guides authored
28 Guide Comments
Where can I purchase the battery?
Boon - Reply Share
@boonspot right here on this site: Kindle 7 (2014) Battery
Nathan T - Reply Share
Fairly easy to do. Saves a lot of money compared to buying a whole new Kindle :) Thank you for this! A note: I've never seen batteries as...soft as these. Take care when using the removal tool. I could be easy to puncture the battery which could cause a big mess and possibly injury.
Joshua - Reply Share
My old battery got seriously deformed during removal, but didn't puncture or tear. I added a picture to the guide, so that hopefully the next person is not as alarmed as I was :)
Where do I get a new battery from please?
Tracy Armstrong - Reply Share
Past 24 Hours: 49
Past 7 Days: 338
Past 30 Days: 1,440
All Time: 71,209
