Up to 20% off select tools
Kindle 2 Wireless Card Replacement
Views: 2.8K
View statistics:
Past 24 Hours:
5
Past 7 Days:
26
Past 30 Days:
107
All Time:
2,783
Comments: 7
6 comments on steps, 1 guide comment.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 - 20 minutes
Difficulty: Moderate
Inconsistent Images
Updating the images on this guide to be more consistent with the prerequisites would increase its awesomeness.
Slice and Dice
The steps in this guide should be split up and made into a series of prerequisite guides.
Parts
Tools
Introduction
Go to step 1 ↓
Use this guide to replace the wireless card in your Kindle 2. Typically, wireless cards stop working due to physical damage, overheating, or simply old age. The Kindle 2 wireless card recognizes wireless networks and allows your device to connect to Wi-Fi. Without a working wireless card, your device may have issues with internet connectivity, dropped connections, or slow speeds. This guide will help you navigate the inside of the product if you are unsure what you are looking at. Always use caution when handling your device as the inner workings of the device may be sensitive when exposed.
    1. Kindle 2 Wireless Card Replacement, Battery: step 1, image 1 of 3 Kindle 2 Wireless Card Replacement, Battery: step 1, image 2 of 3 Kindle 2 Wireless Card Replacement, Battery: step 1, image 3 of 3
      • Lay the Kindle face down on a soft cloth to protect its screen.
      • Wedge the plastic opening tool in the small opening between the grey plastic and the metal casing.
      • Move the plastic opening tool across the opening while pressing down to separate the grey plastic from the metal casing.
      • Slide the gray plastic top piece away from the Kindle's metal casing.
      • Once the gray plastic top piece is detached from the metal back cover, remove it.
      Ask FixBot
    2. Kindle 2 Wireless Card Replacement: step 2, image 1 of 2 Kindle 2 Wireless Card Replacement: step 2, image 2 of 2
      • Use a Phillips #00 screwdriver to remove the two 4 mm screws from the metal casing.
      Ask FixBot
    3. Kindle 2 Wireless Card Replacement: step 3, image 1 of 2 Kindle 2 Wireless Card Replacement: step 3, image 2 of 2
      • Use the plastic opening tool to push down and pry towards the metal casing to release each of the three clips that hold the metal case in place.
      • Remove the metal casing.
      • The volume control button rests in a slot on the side of the Kindle. When the metal casing is removed, the volume control button may fall out. When reassembling, place the volume control button back into its slot.
      Ask FixBot
    4. Kindle 2 Wireless Card Replacement: step 4, image 1 of 1
      • Use a Phillips #00 screwdriver to remove the two 3 mm screws that hold the battery in place.
      • The battery should be removed before continuing with the rest of this guide to prevent harm to you and the device.
      Ask FixBot
    5. Kindle 2 Wireless Card Replacement: step 5, image 1 of 2 Kindle 2 Wireless Card Replacement: step 5, image 2 of 2
      • Pry upward under the black tab with the spudger to dislodge the battery.
      • Use your fingers to lift the battery out of the device.
      Ask FixBot
    1. Kindle 2 Wireless Card Replacement, Wireless Card: step 6, image 1 of 1
      • Rotate the Kindle 180 degrees. Locate the wireless card with the AnyData logo on the top left and the FCC symbol on the right.
      • Use a Phillips #00 screwdriver to remove the two 2mm screws from the wireless card.
      Ask FixBot
    2. Kindle 2 Wireless Card Replacement: step 7, image 1 of 1
      • Use the plastic opening tool to wedge underneath the connection and gently pop off the wire cap.
      Ask FixBot
    3. Kindle 2 Wireless Card Replacement: step 8, image 1 of 2 Kindle 2 Wireless Card Replacement: step 8, image 2 of 2
      • Use your fingers to lift the left end of the wireless card.
      • Pull the card out of the slot.
      Ask FixBot
Author
with
Dayna Scott
985 Reputation
5 Guides authored
Cal Poly, Team 12-32, Amido Spring 2013 Member of Cal Poly, Team 12-32, Amido Spring 2013
CPSU-AMIDO-S13S12G32
4 Members
72 Guides authored
1 Guide Comment
The Kindle 2 in the US only used 2G/3G. Did some other models have a Wi-Fi card instead? It would be cool to swap them out if so to restore functionality.
Navarre - Reply Share
Past 24 Hours: 5
Past 7 Days: 26
Past 30 Days: 107
All Time: 2,783
