Up to 20% off select tools
Kindle 2 Keyboard Replacement
Views: 2.9K
View statistics:
Past 24 Hours:
4
Past 7 Days:
21
Past 30 Days:
110
All Time:
2,880
Comments: 12
12 comments on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 30 - 45 minutes
Difficulty: Difficult
Inconsistent Images
Updating the images on this guide to be more consistent with the prerequisites would increase its awesomeness.
Slice and Dice
The steps in this guide should be split up and made into a series of prerequisite guides.
Tools
Introduction
Go to step 1 ↓
To install a new keyboard into your Kindle 2 requires you to completely disassemble your device, but with this guide it should be fairly simple.
    1. Kindle 2 Keyboard Replacement, Battery: step 1, image 1 of 3 Kindle 2 Keyboard Replacement, Battery: step 1, image 2 of 3 Kindle 2 Keyboard Replacement, Battery: step 1, image 3 of 3
      • Lay the Kindle face down on a soft cloth to protect its screen.
      • Wedge the plastic opening tool in the small opening between the grey plastic and the metal casing.
      • Move the plastic opening tool across the opening while pressing down to separate the grey plastic from the metal casing.
      • Slide the gray plastic top piece away from the Kindle's metal casing.
      • Once the gray plastic top piece is detached from the metal back cover, remove it.
      Ask FixBot
    2. Kindle 2 Keyboard Replacement: step 2, image 1 of 2 Kindle 2 Keyboard Replacement: step 2, image 2 of 2
      • Use a Phillips #00 screwdriver to remove the two 4 mm screws from the metal casing.
      Ask FixBot
    3. Kindle 2 Keyboard Replacement: step 3, image 1 of 2 Kindle 2 Keyboard Replacement: step 3, image 2 of 2
      • Use the plastic opening tool to push down and pry towards the metal casing to release each of the three clips that hold the metal case in place.
      • Remove the metal casing.
      • The volume control button rests in a slot on the side of the Kindle. When the metal casing is removed, the volume control button may fall out. When reassembling, place the volume control button back into its slot.
      Ask FixBot
    4. Kindle 2 Keyboard Replacement: step 4, image 1 of 1
      • Use a Phillips #00 screwdriver to remove the two 3 mm screws that hold the battery in place.
      • The battery should be removed before continuing with the rest of this guide to prevent harm to you and the device.
      Ask FixBot
    5. Kindle 2 Keyboard Replacement: step 5, image 1 of 2 Kindle 2 Keyboard Replacement: step 5, image 2 of 2
      • Pry upward under the black tab with the spudger to dislodge the battery.
      • Use your fingers to lift the battery out of the device.
      Ask FixBot
    1. Kindle 2 Keyboard Replacement, Wireless Card: step 6, image 1 of 1
      • Rotate the Kindle 180 degrees. Locate the wireless card with the AnyData logo on the top left and the FCC symbol on the right.
      • Use a Phillips #00 screwdriver to remove the two 2mm screws from the wireless card.
      Ask FixBot
    2. Kindle 2 Keyboard Replacement: step 7, image 1 of 1
      • Use the plastic opening tool to wedge underneath the connection and gently pop off the wire cap.
      Ask FixBot
    3. Kindle 2 Keyboard Replacement: step 8, image 1 of 2 Kindle 2 Keyboard Replacement: step 8, image 2 of 2
      • Use your fingers to lift the left end of the wireless card.
      • Pull the card out of the slot.
      Ask FixBot
    1. Kindle 2 Keyboard Replacement, Motherboard: step 9, image 1 of 2 Kindle 2 Keyboard Replacement, Motherboard: step 9, image 2 of 2
      • Remove 16 screws from the midframe.
      Ask FixBot
    2. Kindle 2 Keyboard Replacement: step 10, image 1 of 3 Kindle 2 Keyboard Replacement: step 10, image 2 of 3 Kindle 2 Keyboard Replacement: step 10, image 3 of 3
      • Use the plastic opening tool to push each side of the crimp away from each other. This will open the crimp holding the wire.
      • Use your fingers to lift the wire out of the crimp when there is enough separation between the sides of the crimp.
      Ask FixBot
    3. Kindle 2 Keyboard Replacement: step 11, image 1 of 3 Kindle 2 Keyboard Replacement: step 11, image 2 of 3 Kindle 2 Keyboard Replacement: step 11, image 3 of 3
      Tool used on this step:
      Buy
      • Wedge the opening tool underneath the plastic ribbon and gently pull up to lift the brown connector flap.
      • Squeeze the plastic ribbon gently with the tweezers and pull away from the connector to remove it.
      Ask FixBot
    4. Kindle 2 Keyboard Replacement: step 12, image 1 of 1
      • Locate the next brown connector three inches to the right of the previous connector and repeat Step 10 to remove the plastic ribbon.
      Ask FixBot
    5. Kindle 2 Keyboard Replacement: step 13, image 1 of 2 Kindle 2 Keyboard Replacement: step 13, image 2 of 2
      • Rotate the device 180 degrees and locate a smaller brown connector on the left side of the device.
      • Repeat Step 10.
      Ask FixBot
    6. Kindle 2 Keyboard Replacement: step 14, image 1 of 1
      • Push your finger down on the last plastic ribbon.
      • Slide your finger away from the connector to remove the last ribbon.
      Ask FixBot
    7. Kindle 2 Keyboard Replacement: step 15, image 1 of 1
      • Use a Phillips #00 screwdriver to remove the four 4 mm screws from the motherboard located around the LAB126 logo.
      Ask FixBot
    8. Kindle 2 Keyboard Replacement: step 16, image 1 of 1
      • Grab the bottom corner of the motherboard and safely remove it from the Kindle.
      Ask FixBot
    1. Kindle 2 Keyboard Replacement, Keyboard: step 17, image 1 of 1
      • Grab the bottom left corner of the keyboard.
      • Peel the keyboard off the device.
      Ask FixBot
Author
with
Dayna Scott
985 Reputation
5 Guides authored
Cal Poly, Team 12-32, Amido Spring 2013 Member of Cal Poly, Team 12-32, Amido Spring 2013
CPSU-AMIDO-S13S12G32
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 21
Past 30 Days: 110
All Time: 2,880
