Kindle 1st Generation SD Card Reader Replacement
    1. Kindle 1st Generation SD Card Reader Replacement, Battery: step 1, image 1 of 1
      • Slide the grey plastic cover laterally off the back of the device.
      Ask FixBot
    2. Kindle 1st Generation SD Card Reader Replacement: step 2, image 1 of 2 Kindle 1st Generation SD Card Reader Replacement: step 2, image 2 of 2
      • Use a plastic opening tool to lift the battery on the side closest to the edge of the device.
      • Unplug the battery from the device by pinching the white connector and pulling.
      • Do not yank the battery or try to disconnect the battery by pulling the wires.
      Ask FixBot
    1. Kindle 1st Generation SD Card Reader Replacement, SD Card Reader: step 3, image 1 of 1
      • Unscrew eight (8) Phillips #00 screws (3 mm).
      Ask FixBot
    2. Kindle 1st Generation SD Card Reader Replacement: step 4, image 1 of 2 Kindle 1st Generation SD Card Reader Replacement: step 4, image 2 of 2
      • Start at one side of the device. Use a plastic opening tool to separate the casing of the device. Slowly work your way around the entire device.
      • Avoid prying between the buttons and the device. This could cause damage to the buttons.
      Ask FixBot
    3. Kindle 1st Generation SD Card Reader Replacement: step 5, image 1 of 2 Kindle 1st Generation SD Card Reader Replacement: step 5, image 2 of 2
      • Unscrew the two (2) Phillips #00 screws (3 mm) which fasten the metal casing shield.
      • Slowly remove the metal casing shield by lifting it and carefully peeling up the tape.
      Ask FixBot
    4. Kindle 1st Generation SD Card Reader Replacement: step 6, image 1 of 1
      • Remove the four (4) Phillips #00 screws (3 mm) which fasten the SD Card Reader.
      Ask FixBot
    5. Kindle 1st Generation SD Card Reader Replacement: step 7, image 1 of 2 Kindle 1st Generation SD Card Reader Replacement: step 7, image 2 of 2
      • Lift the flap attaching the blue and white ribbon cable to the motherboard by lifting it vertically with a spudger.
      • The flap is connected via a hinge. Once you lift the flap, it will stay up and the cable will be lose. Remember to snap it back down during reassembly.
      • Carefully lift the SD Card Reader vertically from the motherboard.
      Ask FixBot
2 other people completed this guide.
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 30
Past 30 Days: 116
All Time: 2,460
