Up to 20% off select tools
Kindle 10 Motherboard Replacement
Views: 1.3K
View statistics:
Past 24 Hours:
3
Past 7 Days:
26
Past 30 Days:
122
All Time:
1,253
Comments: 1
1 comment on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 20 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
If you have complications with your Kindle 10, including heating issues, unresponsiveness, or the device not turning on, this may indicate that you need to replace the motherboard.
    1. Kindle 10 Motherboard Replacement, Battery: step 1, image 1 of 2 Kindle 10 Motherboard Replacement, Battery: step 1, image 2 of 2
      • Gently use a metal spudger to pry, twist, and lift the bezel away from the display.
      Ask FixBot
    2. Kindle 10 Motherboard Replacement: step 2, image 1 of 1
      • Remove the eight 2.6 mm screws using a T5 Torx screwdriver.
      Ask FixBot
    3. Kindle 10 Motherboard Replacement: step 3, image 1 of 2 Kindle 10 Motherboard Replacement: step 3, image 2 of 2
      • Use the metal spudger to gently lift the screen out of the back frame.
      Ask FixBot
    4. Kindle 10 Motherboard Replacement: step 4, image 1 of 1
      • Detach the battery connector from the motherboard.
      • The battery pack may be glued on to the gray plastic frame. Take care when prying it out not to rip the battery, since it is made of a lithium polymer which is flammable and deforms easily.
      Ask FixBot
    1. Kindle 10 Motherboard Replacement, Motherboard: step 5, image 1 of 3 Kindle 10 Motherboard Replacement, Motherboard: step 5, image 2 of 3 Kindle 10 Motherboard Replacement, Motherboard: step 5, image 3 of 3
      • Remove the two outer silver screws with a T5 Torx screwdriver.
      • Use your fingers to remove the two gold screws in the middle.
      Ask FixBot
    2. Kindle 10 Motherboard Replacement: step 6, image 1 of 3 Kindle 10 Motherboard Replacement: step 6, image 2 of 3 Kindle 10 Motherboard Replacement: step 6, image 3 of 3
      • Disconnect the two orange clear plastic ribbons on the upper right and center.
      Ask FixBot
    3. Kindle 10 Motherboard Replacement: step 7, image 1 of 2 Kindle 10 Motherboard Replacement: step 7, image 2 of 2
      • Pry the motherboard away from the display frame
      Ask FixBot
Author
with
John Ready
159 Reputation
1 Guide authored
UMass Dartmouth, Team 1-2, Konn Fall 2024 Member of UMass Dartmouth, Team 1-2, Konn Fall 2024
UMASSD-KONN-F24S1G2
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 26
Past 30 Days: 122
All Time: 1,253
