Parts
LED BulbsAffiliate linkAvailable for sale on Amazon
It should have soldering joints to the left and right, not below it. It should be 3.0mm and lay flat, like in the picture.
Tools
Spudger4.9
Introduction
Go to step 1 ↓The LED light on the Kindle 10 is a sturdy and efficient piece of technology connected to the motherboard that indicates different statuses: a blinking orange for charging and continuously lit when charged. It is not expected to need replacement for its filament should last over 100 years. There may be issues with the light if the Kindle is functional but the light does not react to actions such as charging or powering off. If its soldering points become disconnected or the filament does burn out, we can replace this light.
Gently use a metal spudger to pry, twist, and lift the bezel away from the display.
Remove the two outer silver screws with a T5 Torx screwdriver.
Use your fingers to remove the two gold screws in the middle.
Turn on the soldering iron.
Clean the tip after the old solder has melted by dragging it across a sponge.
Prime the soldering iron by touching its tip with a dab of lead-free wire. Your soldering iron is ready when the solder readily melts.
