Up to 20% off select tools
Kindle 10 Battery Replacement
Views: 7.1K
View statistics:
Past 24 Hours:
21
Past 7 Days:
174
Past 30 Days:
693
All Time:
7,132
Comments: 4
1 comment on steps, 3 guide comments.
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 minutes
Difficulty: Moderate
Parts
Tools
Introduction
Go to step 1 ↓
If you discover any issues such as quickly draining battery, freezing, overheating, or charging problems, this could indicate that you need to replace your battery. Through using this guide, you can learn the proper way to conduct a battery replacement for the Kindle 10.
    1. Kindle 10 Battery Replacement, Battery: step 1, image 1 of 2 Kindle 10 Battery Replacement, Battery: step 1, image 2 of 2
      • Gently use a metal spudger to pry, twist, and lift the bezel away from the display.
      Ask FixBot
    2. Kindle 10 Battery Replacement: step 2, image 1 of 1
      • Remove the eight 2.6 mm screws using a T5 Torx screwdriver.
      Ask FixBot
    3. Kindle 10 Battery Replacement: step 3, image 1 of 2 Kindle 10 Battery Replacement: step 3, image 2 of 2
      • Use the metal spudger to gently lift the screen out of the back frame.
      Ask FixBot
    4. Kindle 10 Battery Replacement: step 4, image 1 of 1
      • Detach the battery connector from the motherboard.
      • The battery pack may be glued on to the gray plastic frame. Take care when prying it out not to rip the battery, since it is made of a lithium polymer which is flammable and deforms easily.
      Ask FixBot
2 other people completed this guide.
Author
with
hzheng2
603 Reputation
4 Guides authored
UMass Dartmouth, Team 1-2, Konn Fall 2024 Member of UMass Dartmouth, Team 1-2, Konn Fall 2024
UMASSD-KONN-F24S1G2
3 Members
60 Guides authored
3 Guide Comments
Do you have any replacements if we break the case ?
Calixte Marbach - Reply Share
The affiliate-linked battery is incorrect. Don’t make the mistake I made. Do not purchase it.
dj TA630 - Reply Share
@djta630 I just found this out the hard way as well. Fortunately, it’s only a few bucks, but definitely frustrating.
kennethbaese - Reply Share
Past 24 Hours: 21
Past 7 Days: 174
Past 30 Days: 693
All Time: 7,132
