Up to 20% off select tools
Kilgone G20 Battery Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
21
Past 30 Days:
87
All Time:
640
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 20 - 30 minutes
Difficulty: Very difficult
Parts
Tools
Introduction
Go to step 1 ↓
The battery is the heart of your Kilgone G20, powering it through each cleaning cycle. Over time, batteries can lose capacity, leading to shorter run times or charging issues. Replacing the battery is a straightforward process that can breathe new life into your robot vacuum.
    1. Kilgone G20 Battery Replacement, Battery: step 1, image 1 of 2 Kilgone G20 Battery Replacement, Battery: step 1, image 2 of 2
      • Remove the mop pad.
      Ask FixBot
    2. Kilgone G20 Battery Replacement: step 2, image 1 of 2 Kilgone G20 Battery Replacement: step 2, image 2 of 2
      • One at a time, grab and pull up on each of the side brushes to remove them.
      • Don't be afraid to use some force when pulling up on each of the brushes.
      Ask FixBot
    3. Kilgone G20 Battery Replacement: step 3, image 1 of 3 Kilgone G20 Battery Replacement: step 3, image 2 of 3 Kilgone G20 Battery Replacement: step 3, image 3 of 3
      • Pinch on the tab and pull out the mopping solution container.
      Ask FixBot
    4. Kilgone G20 Battery Replacement: step 4, image 1 of 1
      • Use a Phillips #1 screwdriver to remove the ten 3.8 mm x 12.28 mm screws on the underside of the device.
      Ask FixBot
    5. Kilgone G20 Battery Replacement: step 5, image 1 of 3 Kilgone G20 Battery Replacement: step 5, image 2 of 3 Kilgone G20 Battery Replacement: step 5, image 3 of 3
      • Remove the six 2.3 mm screws on the underside of the bumper.
      • Lift the undersides of the bumper off.
      Ask FixBot
    6. Kilgone G20 Battery Replacement: step 6, image 1 of 3 Kilgone G20 Battery Replacement: step 6, image 2 of 3 Kilgone G20 Battery Replacement: step 6, image 3 of 3
      • Lift the entire underside up cautiously.
      • Make sure not to pull or snap the wire connected to the main board.
      Ask FixBot
    7. Kilgone G20 Battery Replacement: step 7, image 1 of 2 Kilgone G20 Battery Replacement: step 7, image 2 of 2
      • Grab the main circuit board and look for which port the bumper is attached to.
      • Carefully pull out the connection and put the bumper off to the side.
      Ask FixBot
    8. Kilgone G20 Battery Replacement: step 8, image 1 of 3 Kilgone G20 Battery Replacement: step 8, image 2 of 3 Kilgone G20 Battery Replacement: step 8, image 3 of 3
      • Flip over the G20.
      • Remove the two M3 x 10 screws that secure the battery cover.
      • Remove the battery cover.
      Ask FixBot
    9. Kilgone G20 Battery Replacement: step 9, image 1 of 2 Kilgone G20 Battery Replacement: step 9, image 2 of 2
      • Unplug the cable that's connected to the battery from the port on the motherboard.
      • Make sure you only disconnect the cable that is highlighted in the image.
      Ask FixBot
    10. Kilgone G20 Battery Replacement: step 10, image 1 of 2 Kilgone G20 Battery Replacement: step 10, image 2 of 2
      • Flip over the G20 again, and gently lift out the battery along with the wire that it's connected to.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Author
with
Sol
381 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 21
Past 30 Days: 87
All Time: 640
