Kidzlane Walkie-Talkie Power Button Replacement
  1. Kidzlane Walkie-Talkie Power Button Replacement, Power Button: step 1, image 1 of 2 Kidzlane Walkie-Talkie Power Button Replacement, Power Button: step 1, image 2 of 2
    • Use a screwdriver to remove the four pictured 4mm screws.
    Ask FixBot
  2. Kidzlane Walkie-Talkie Power Button Replacement: step 2, image 1 of 1
    • Slowly separate the cases of the device. Try not to damage the wires connecting the two pieces.
    • Keep the two pieces away from each other so you can follow the next step accordingly.
    Ask FixBot
  3. Kidzlane Walkie-Talkie Power Button Replacement: step 3, image 1 of 2 Kidzlane Walkie-Talkie Power Button Replacement: step 3, image 2 of 2
    • Use the soldering iron to remove the broken switch.
    • Push down on the metal locks to separate the switch from the motherboard.
    Ask FixBot
2 other people completed this guide.
Amin
644 Reputation
5 Guides authored
IUPUI, Team 1-1, Wilson Spring 2016 Member of IUPUI, Team 1-1, Wilson Spring 2016
IUPUI-WILSON-S16S1G1
4 Members
5 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 42
All Time: 919
