Kidde i2040A Battery Replacement
    1. Kidde i2040A Battery Replacement, Battery: step 1, image 1 of 2 Kidde i2040A Battery Replacement, Battery: step 1, image 2 of 2
      • Use a ladder to reach the smoke alarm.
      • Twist the alarm clockwise to unhook the smoke alarm from the ceiling.
      • The smoke alarm is still attached with a wiring harness.
      Ask FixBot
    2. Kidde i2040A Battery Replacement: step 2, image 1 of 2 Kidde i2040A Battery Replacement: step 2, image 2 of 2
      • Push down on the clips on each side of the wire to detach the alarm from the wire harness.
      • When the clips are pushed down, pull down to detach the wire.
      Ask FixBot
    3. Kidde i2040A Battery Replacement: step 3, image 1 of 3 Kidde i2040A Battery Replacement: step 3, image 2 of 3 Kidde i2040A Battery Replacement: step 3, image 3 of 3
      • Push the white button on the inside of the alarm to open the battery compartment.
      • Remove the battery from the compartment.
      • Replace with a new battery.
      Ask FixBot
    4. Kidde i2040A Battery Replacement: step 4, image 1 of 1
      • Close the battery compartment door.
      Ask FixBot
    5. Kidde i2040A Battery Replacement: step 5, image 1 of 3 Kidde i2040A Battery Replacement: step 5, image 2 of 3 Kidde i2040A Battery Replacement: step 5, image 3 of 3
      • Reconnect the wire to the alarm.
      Ask FixBot
    6. Kidde i2040A Battery Replacement: step 6, image 1 of 2 Kidde i2040A Battery Replacement: step 6, image 2 of 2
      • Align the alarm’s slots with the notches on the ceiling-mounted base.
      Ask FixBot
    7. Kidde i2040A Battery Replacement: step 7, image 1 of 1
      • When aligned, turn the alarm counterclockwise to lock it in place.
      • Confirm that the alarm won't fall off, and now you have completed the steps to replace a smoke alarm battery!
      Ask FixBot
When you have completed these steps, you will be able to replace future smoke alarm batteries on the whim!
You will also be able to educate friends or family on how to complete this task as well.
Alyze Escobedo
145 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 28
Past 30 Days: 148
All Time: 997
