Kid Galaxy Morphibians Explorer On/Off Switch Replacement
    1. Kid Galaxy Morphibians Explorer On/Off Switch  Replacement, Remove the Top Cover: step 1, image 1 of 1
      • First, completely loosen the 9.6 mm Phillips #2 screw on top. There is a plastic washer that holds the screw to the top cover, so it will not need to be taken out.
      Ask FixBot
    2. Kid Galaxy Morphibians Explorer On/Off Switch  Replacement: step 2, image 1 of 1
      • After the screw has been loosened, lift the cover off.
      Ask FixBot
    3. Kid Galaxy Morphibians Explorer On/Off Switch  Replacement: step 3, image 1 of 1
      • Completely loosen the 9.6 mm Phillips #2 screw from the battery cover. Once again, there is a plastic washer to hold the screw to the cover.
      Ask FixBot
    4. Kid Galaxy Morphibians Explorer On/Off Switch  Replacement: step 4, image 1 of 1
      • After the screw is loosened, lift the battery cover off the top cover to gain access to the batteries.
      • Turn the RC car over to reach the six screws on the bottom.
      Ask FixBot
    5. Kid Galaxy Morphibians Explorer On/Off Switch  Replacement: step 5, image 1 of 1
      • Remove the six 11.6 mm Phillips #2 screws on the bottom cover.
      • (Wheels are removed in this picture to clearly show screw location. They do not need to be removed for this step)
      Ask FixBot
    6. Kid Galaxy Morphibians Explorer On/Off Switch  Replacement: step 6, image 1 of 1
      • Lift the top Cover off the car.
      Ask FixBot
    1. Kid Galaxy Morphibians Explorer On/Off Switch  Replacement, On/Off Switch: step 7, image 1 of 1
      • On the top of the inside cover you will see the back side of the on/off switch. Remove the two 7.2 mm Philips #00 head screws holding the switch in place.
      Ask FixBot
    2. Kid Galaxy Morphibians Explorer On/Off Switch  Replacement: step 8, image 1 of 1
      • Gently pull the on/off switch off the inside cover.
      • Remove the positive (red wire) and negative (black wire) terminals from the bottom of the batter cover. Snip the wires using wire cutters.
      • Remove to freed on/off switch from the inside cover.
      Ask FixBot
Eric Studstrup
4 Reputation
2 Guides authored
USF Tampa, Team 1-2, Hickman Fall 2014 Member of USF Tampa, Team 1-2, Hickman Fall 2014
USFT-HICKMAN-F14S1G2
3 Members
84 Guides authored
1 Guide Comment
In the last step, Step 8 second bullet. Could add a image of actually showing how its done.
Dishant Patel - Reply Share
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 25
All Time: 937
