Kid Galaxy Morphibians Explorer Battery Replacement
  1. Kid Galaxy Morphibians Explorer Battery Replacement, Battery: step 1, image 1 of 1
    • First, completely loosen the 9.6 mm Phillips #2 screw on top. There is a plastic washer that holds the screw to the top cover, so it will not need to be taken out.
    Ask FixBot
  2. Kid Galaxy Morphibians Explorer Battery Replacement: step 2, image 1 of 1
    • After the screw has been loosened, lift the cover off.
    Ask FixBot
  3. Kid Galaxy Morphibians Explorer Battery Replacement: step 3, image 1 of 1
    • Completely loosen the 9.6 mm Phillips #2 screw from the battery cover. Once again, there is a plastic washer to hold the screw to the cover.
    Ask FixBot
  4. Kid Galaxy Morphibians Explorer Battery Replacement: step 4, image 1 of 1
    • Lift the battery cover to gain access to the batteries.
    • Replace the 3 AA batteries and reverse the steps to put everything back together.
    Ask FixBot
Rusbell Gonzalez
219 Reputation
5 Guides authored
USF Tampa, Team 1-2, Hickman Fall 2014 Member of USF Tampa, Team 1-2, Hickman Fall 2014
USFT-HICKMAN-F14S1G2
3 Members
7 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 29
All Time: 3,295
