Kia Rio Inner Car Door Handle Replacement
Views: 5.5K
View statistics:
Past 24 Hours:
3
Past 7 Days:
37
Past 30 Days:
131
All Time:
5,458
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 45 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
This project will require taking off some bolts or screws that may be difficult to loosen. Although not required, an impact driver or impact wrench may be suggested. This is quite easy to follow but the individual steps may be difficult. If your car is older or live in a rainy place then the project may be difficult.
Tools
    1. Kia Rio Inner Car Door Handle Replacement, Inner Car Door Handle: step 1, image 1 of 2 Kia Rio Inner Car Door Handle Replacement, Inner Car Door Handle: step 1, image 2 of 2
      • Find all the caps hiding the screws and remove them.
      • These are typically found in the door handle, the side of the door near the top, and in the middle of the door panel.
      Ask FixBot
    2. Kia Rio Inner Car Door Handle Replacement: step 2, image 1 of 3 Kia Rio Inner Car Door Handle Replacement: step 2, image 2 of 3 Kia Rio Inner Car Door Handle Replacement: step 2, image 3 of 3
      • Remove all screws holding the door panel in place.
      • These are typically found in the middle of the door panel, on the side of the door and on the bottom right side of the door panel.
      Ask FixBot
    3. Kia Rio Inner Car Door Handle Replacement: step 3, image 1 of 2 Kia Rio Inner Car Door Handle Replacement: step 3, image 2 of 2
      • Remove the screw on the door handle.
      • Remove the handle's cover.
      Ask FixBot
    4. Kia Rio Inner Car Door Handle Replacement: step 4, image 1 of 1
      • Remove the screw holding the door handle to the door frame.
      Ask FixBot
    5. Kia Rio Inner Car Door Handle Replacement: step 5, image 1 of 3 Kia Rio Inner Car Door Handle Replacement: step 5, image 2 of 3 Kia Rio Inner Car Door Handle Replacement: step 5, image 3 of 3
      • Remove window crank handle using the handle removal tool using the orientations seen in the first and second pictures.
      • The handle removal tool works by removing the clip seen in the third picture.
      Ask FixBot
    6. Kia Rio Inner Car Door Handle Replacement: step 6, image 1 of 2 Kia Rio Inner Car Door Handle Replacement: step 6, image 2 of 2
      • Remove the door panel by pushing upwards.
      • Although not very difficult to take off, use proper squatting form to ensure you don't hurt yourself.
      Ask FixBot
    7. Kia Rio Inner Car Door Handle Replacement: step 7, image 1 of 2 Kia Rio Inner Car Door Handle Replacement: step 7, image 2 of 2
      • Use a sharp knife to cut the strip calk connecting the top half of the moisture shield.
      • Pull the moisture shield half way down.
      • Don't tear the moisture shield cover.
      • The strip calk will still work as an adhesive once taken off so you can stick the moisture shield back onto the door frame.
      Ask FixBot
    8. Kia Rio Inner Car Door Handle Replacement: step 8, image 1 of 2 Kia Rio Inner Car Door Handle Replacement: step 8, image 2 of 2
      • Remove the door handle from the door frame.
      • Remove the wires from the door handle.
      • Put on your replacement door handle.
      Ask FixBot
2 other people completed this guide.
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 37
Past 30 Days: 131
All Time: 5,458
