This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
Community-Contributed Guide
Tools
Introduction
Go to step 1 ↓Follow this guide to remove or replace the battery of a Keychron K10 HE wireless mechanical keyboard.
The keyboard functions normally without a battery; removing it for wired use helps ensure the longevity of the keyboard (preventing battery swelling and wear). This guide also covers the disassembly steps for replacing it in case of wear.
Using the 2 mm Allen key, remove the two screws securing the wooden side panels on each side of the keyboard.
Remove the two aluminum rails that were held by the wooden studs
Remove the keyboard keys to access the circled screws
Remove the 11 Phillips screws securing the front panel
With the front panel lifted, gently disconnect the battery connector.
Then remove the two plates underneath: the first made of foam and the second made of silicone.
To reassemble your device, follow the instructions in reverse order.
