Keurig K70 Handle Replacement
Views: 1.6K
View statistics:
Past 24 Hours:
Past 7 Days:
17
Past 30 Days:
82
All Time:
1,598
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 minutes
Difficulty: Very easy
Introduction
Go to step 1 ↓
If your Keurig K70 does not close properly you may need to replace the handle. This guide will walk you through the necessary steps to do so. It is an easy fix but requires an uncommon tool.
Tools
    1. Keurig K70 Handle Replacement, Handle: step 1, image 1 of 2 Keurig K70 Handle Replacement, Handle: step 1, image 2 of 2
      • Locate the handle on top of the unit
      • Locate the two Torx head screws on the underside of the handle. Remove them with a T15 screwdriver
      Ask FixBot
    2. Keurig K70 Handle Replacement: step 2, image 1 of 3 Keurig K70 Handle Replacement: step 2, image 2 of 3 Keurig K70 Handle Replacement: step 2, image 3 of 3
      • Bend the handle outward to remove
      Ask FixBot
Westin McHaney
143 Reputation
1 Guide authored
Cal Poly, Team 20-4, Livingston Fall 2016 Member of Cal Poly, Team 20-4, Livingston Fall 2016
CPSU-LIVINGSTON-F16S20G4
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 17
Past 30 Days: 82
All Time: 1,598
