Keurig K55 Water Filter Replacement
Views: 3.4K
View statistics:
Past 24 Hours:
8
Past 7 Days:
34
Past 30 Days:
124
All Time:
3,434
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 minutes
Difficulty: Very easy
Introduction
Go to step 1 ↓
Replacing a Keurig water filter will help your machine run smoother. This also helps improve the quality of brews.
    1. Keurig K55 Water Filter Replacement, Charcoal water filter: step 1, image 1 of 1
      • Soak the new charcoal filter in water for 5 minutes.
      Ask FixBot
    2. Keurig K55 Water Filter Replacement: step 2, image 1 of 3 Keurig K55 Water Filter Replacement: step 2, image 2 of 3 Keurig K55 Water Filter Replacement: step 2, image 3 of 3
      • Remove the water reservoir from the Keurig machine by gently lifting up on the reservoir and pulling it away.
      Ask FixBot
    3. Keurig K55 Water Filter Replacement: step 3, image 1 of 1
      • Remove the lid from the water reservoir and empty any remaining water from the tank.
      Ask FixBot
    4. Keurig K55 Water Filter Replacement: step 4, image 1 of 2 Keurig K55 Water Filter Replacement: step 4, image 2 of 2
      • Remove water filter holder from within the water reservoir by pulling up on the holder and lifting it out.
      Ask FixBot
    5. Keurig K55 Water Filter Replacement: step 5, image 1 of 2 Keurig K55 Water Filter Replacement: step 5, image 2 of 2
      • To remove the old filter, pinch both sides of the filter holder at the base and pull it apart. Remove the old filter by lifting it out of the filter holder.
      • Dispose of old water filter cartridge.
      Ask FixBot
    6. Keurig K55 Water Filter Replacement: step 6, image 1 of 1
      • Take the soaked water filter and rinse it under running water for 60 seconds.
      Ask FixBot
    7. Keurig K55 Water Filter Replacement: step 7, image 1 of 2 Keurig K55 Water Filter Replacement: step 7, image 2 of 2
      • Place new water filter cartridge into the upper filter holder.
      • Snap the bottom of the filter holder back on by aligning the tabs with the spaces
      Ask FixBot
Maria Kostourkova
160 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 8
Past 7 Days: 34
Past 30 Days: 124
All Time: 3,434
